Old 03-07-2017, 05:33 PM   #4
39portlander
39portlander's Avatar
Default Re: adding second mechanical oil pressure gauge
Here is my arrangement on the 39 P/U, the first pick is an actual gauge with a ball valve that I can observe while out of the cab.
The second picture is the sending unit installed were the original one would be for a newer oil psi gauge in the cab next to fuel, H2O temp and volts.
39portlander is offline   Reply With Quote
