#21 | |
You're already off to a good start with that area you buffed on the trunk .Ken
https://www.nirgv8.org |
#22 | |
Books are here: https://www.earlyfordv8.org/store-products.cfm?id=2 Judging forms and standards are here: http://www.earlyfordv8.org/early-ford-forms.cfm One more thing. You've got to get yourself the "Green Bible." It's the 800 page parts book that lists every part for every Ford from 1928 thru 1948. If you wonder whether your car had a part or which part is right for your car, it will tell you and often show you with a diagram. There are several for sale right now on ebay for about $70.00 or you can get it on CD for about $30.00 here: http://cgi.ebay.com/ebaymotors/Ford-...item53e58aad27
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end. *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 01-13-2011 at 12:34 PM. |
#23 |
im back workin on my39 pickup gonna make it as stock as possible, have pic but havent got a way to get them on computer yet. stock motor all done and running 12 volt not stock but practical driver 4 me now on to body work lots of body work.
#24 |
#25 |
Here is a studio shot of my 49 when I went to the Grand National in 2008. This is as original as I could get it. Drove over 700 miles each way. Two 1 day trips. I believes stock will give you the most reliability as it is tried and proven. I painted this car the original gray against others advice. I have had more compliments on a gray car than I would have thought possible. I can appreciate modified but this works for me.
The technique of infamy is to start two lies at once and get people arguing heatedly over which is true. ~ Ezra Pound |
#26 |
#27 |
I can barley keep my junkers running. I do like driving to National meets. Sometimes I am in the Touring class but that good enough for me.I did scrounge up a 50 Ford Crestliner for a driver I hope some day. It looks good but so far I have repaired the wireing,rebuilt steering box and front end end,tires,brakes, dist,rebuilt the gen.,and that just for a start.Maybe someday it will meet my standard as a decent driver.
#28 |
1941 Ford 1/2ton, correct except for an accessory column mounted signal switch.
#29 |
Heres are a couple .
#30 |
The other one.
#31 |
Super Moderator
One more thing. You've got to get yourself the "Green Bible." It's the 800 page parts book that lists every part for every Ford from 1928 thru 1948. If you wonder whether your car had a part or which part is right for your car, it will tell you and often show you with a diagram. There are several for sale right now on ebay for about $70.00 or you can get it on CD for about $30.00 here: http://cgi.ebay.com/ebaymotors/Ford-...item53e58aad27[/QUOTE]
The HUGE PROBLEM with the Green Book is the parts listed are service (replacement) parts and VERY OFTEN not authentic to the car when it was built. Yes, the green book as well as any Ford parts book is helpful but will not necessarily allow the correct information for a top point restoration. To lessen the pitfalls of what I've mentioned above, it is best to get a parts book published as close to possible as to when your particular vehicle was built. Remember, just because the part fits, doesn't make it correct. |
#32 |
All judging standards differ in some details. Thus, if you're going for points awarded by a particular organization, you've got to comply with their standards, regardless of what was really correct for your vehicle. Usually the standards of clubs like Early Ford V8 Club are closest to reality because that's their goal but still, to get "top points" for your restoration, it's got to be according to the judging standards that you're competing under.
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end. *Ursula K. Le Guin in The Left Hand of Darkness |
#33 |
So, where do we get such a book of which you speak? I only know of the Green Bible and how to get that.
#34 |
[QUOTE=Kube;142787]The HUGE PROBLEM with the Green Book is the parts listed are service (replacement) parts and VERY OFTEN not authentic to the car when it was built.QUOTE]
The book does identify original part numbers that have been superceded by later numbers and even newer parts to replace them with. I think it's a great source of information although perhaps not the final definitive source (whatever that may be.)
Prof. Henry (The Roaming Gnome) ![]() "It is good to have an end to journey toward; but it is the journey that matters, in the end. *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 01-13-2011 at 07:32 PM. |
#35 | |
#36 |
You posted the best pictures there were. Hope you didn't think I was taking credit. And thank you again for posting all of those.
#37 | |
#38 |
Here's a 40 that this 83 years young fellow did from his memory only, no books. We did the metal work and paint but he completely disassembled and reassembled it himself with his 82 year old wife's assistance. Not a 100 pointer but pretty darn good for eight decade old hands and joints.
#39 | |
#40 | |
TM |
