For cars that were not equipped with the optional (?) door switch to automatically turn on/off the courtesy light, was there a rubber delete plug the cover the hole ? (see yellow arrow in the attached photo). The car on the left (my Dad's) seems to have had such a cover; the one on the right (mine) does not.
If they exist, where can I obtain a pair?
--------------------- '59 Custom 300 - Fordor. Last edited by Green&White; 01-29-2017 at 01:15 AM. Reason: Typo |
My '61 Fairlane is a switch delete and it did not have a plug there, just the same type of hole as your '59.
I've heard of them possibly having plugs but I'm 99.9% sure my car never had one. My car was untouched when I bought it and they are missing on both sides. |
You might try measuring the size of the hole then trying one of those rubber body plugs. Different sized plugs are available from all the normal suppliers. Dennis Carpenter, Macs and others.
Dan Kingman Az. 86409 |
deleted
. Last edited by dmsfrr; 01-31-2017 at 11:51 AM. |
Many home hardware stores have: rubber plugs, caps, specialty nuts, threaded inserts and misc handy do-dads on the aisle with drawer pulls and cabinet handles.
I have never seen one plugged before. Even the lowly Custom 300 had the switches on both sides. You could try to see if Steele Rubber makes one, plug in what car you have and it generates a list. Any standard body plug will work once you know the size.
Interesting. If door switches were standard on the Custom, then maybe what I'm (barely) seeing in the B & W photo is the switch.
- Would it have looked like in the attached photo ? - Would the Fordor have had it on the back doors as well ? If mine were removed for repaint, then I would think the wires are still in there somewhere. If not, what additional wiring / hardware / dis & re-assembly would I need to get it working ? Thanks
--------------------- '59 Custom 300 - Fordor. Last edited by Green&White; 02-02-2017 at 11:53 AM. Reason: Add photo |
I've seen photos of the rubber plugs. Here are a couple examples:
--------------------- '59 Custom 300 - Fordor. |
if you go to Jeffs 52-59 ford social forum on the HAMB. look at dagels build there are shots of the door jambs showing plugs.look pretty original.if you do not belong it would benefit you to join.
How do I get to and join the social forums? I'm not very HAMB-savy.
#13 |
#14 |
#15 |
find the size of the hole, then go to the wrecking yard and get what you need ofrom cars or truck door bumpers
