Old 12-11-2016, 04:56 PM   #1
30-9
Default 40 coupe with dual edlebrocks
Hi
My 40 has a Offy manifold with dual edlebrock 94s. Currently I have a K&N filter on each. I was wondering and looked for an cool single air filter that would cover both carbs. I searched ebay but could only find ones for 4 barrel carbs.
You folks know of any available?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 12-11-2016, 05:13 PM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: 40 coupe with dual edlebrocks
Baron Tattersfield Hexagontool and Eddie meier available it´s depending on what spacing you have on the carbs.
And i got the above from a quick search on Epray so give it another go
Old 12-11-2016, 06:04 PM   #3
flatjack9
flatjack9's Avatar
Check out O'Brien Truckers. They have what you want.
Old 12-12-2016, 09:51 AM   #4
41Joe
41Joe's Avatar
Personally I have always liked the Thickstun air cleaner. But it would only fit on the regular dual manifold, not the super dual.
http://www.seabrighthotrods.com/?p=1599
I hope that link works.
41Joe is offline   Reply With Quote
Old 12-12-2016, 12:11 PM   #5
adileo
adileo's Avatar
These (lower are for 2 barrel) are expensive but I like
adileo is offline   Reply With Quote
Old 12-12-2016, 02:48 PM   #6
Matt in Alameda
Adileo, where do you find these dual air cleaner set-ups? .....Matt in Alameda
Matt in Alameda is offline   Reply With Quote
Old 12-12-2016, 02:53 PM   #7
adileo
adileo's Avatar
O'Brian Truckers web site.
Old 12-12-2016, 03:00 PM   #8
Vic Piano
Vic Piano's Avatar
I believe that the Thickstun dual teardrop style air cleaner is reproduced however, I've not looked for one so I can't give you any suggestions as to who makes them or where you might find one.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 12-12-2016, 03:10 PM   #9
41Joe
41Joe's Avatar
I just went on that O'Brien Truckers website and found this:
https://www.obrientruckers.com/ecom/product/239/2390/
It's not bad looking and very versatile.
Old 12-12-2016, 03:12 PM   #10
41Joe
41Joe's Avatar
Just found this one one eBay:
http://www.ebay.com/itm/Thickstun-Ed...25.m3641.l6368
Old 12-12-2016, 03:31 PM   #11
B-O-B
B-O-B's Avatar
41 Joe;
Use your good eye & read the whole ad. That is for an element only
THIS IS THE AIR CLEANER ELEMENT ONLY. NO AIR CLEANER.
B-O-B is offline   Reply With Quote
Old 12-12-2016, 03:35 PM   #12
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by 41Joe View Post
Note: As seen from the cut and paste below, this is the ELEMENT ONLY ...NO Air Cleaner! DD
"THIS IS THE AIR CLEANER ELEMENT ONLY. NO AIR CLEANER."
Click Links Below __
T5 W/TORQUE TUBE
Old 12-12-2016, 03:58 PM   #13
41Joe
41Joe's Avatar
My bad.
Here you go.
http://www.ebay.com/itm/Thickstun-19...5TYWbX&vxp=mtr
