11-26-2016, 01:19 PM | #1 |
brake lines ?
I am replacing brake lines on my chassis and I need to connect two length of 3/16 line. Can I use a compression o ring fitting or must I double flare both ends? I think I heard compression rings are a no no? But its been a long time since I have done this kind of thing.
11-26-2016, 01:31 PM | #2 |
Re: brake lines ?
Double flare.
11-26-2016, 01:41 PM | #3 |
Re: brake lines ?
There is a fitting that accepts flare lines that you can connect the two lines.
11-26-2016, 01:51 PM | #4 |
Re: brake lines ?
Needs to be double flare. A compression fitting is not designed for that much pressure.
11-26-2016, 04:37 PM | #5 |
Re: brake lines ?
Absolutely do not use a compression fitting. Suicide waiting to happen. Use a union fitting that will accept the flared fittings.
Barry 50 F-1 |
11-26-2016, 06:03 PM | #6 |
Re: brake lines ?
