Originally Posted by rotorwrench
The 49 Merc is different than the 50/51. It has a lever under the dash that the hand brake control tube is attached to on one end then the lever is pinned to the structure under the dash. The brake cable should have a forked clevis on the end of it that uses a clevis pin to attach to the fulcrum lever.
Originally Posted by Bob C
Rotorwrench is correct. 1949 cable is 8M-2853 and 1950-51 is OM-2853.
Bob
Originally Posted by Automotive Stud
Yes that sounds more like what I have. Thanks!
Yes, indeed the '49 Merc. E-brake is different than the '50-'51.
This is what it should be.
