Old 10-26-2016, 10:48 PM   #9
Flatout
Flatout's Avatar
Default Re: 34 manifold to stock 32 engine
I would recommend using a 37 intake on a 32 engine if it's installed in a 32. The original 32 intake mounts the generator down low, as does the 37 intake. This positions the fan blades low enough to clear the radiator tank and still will allow adjustment as the belt wears. Use the appropriate length fuel pump push rod, and generator.
Flatout is offline   Reply With Quote
