Old 10-26-2016, 03:43 PM   #1
rusted
Default pressure plate fingers
On a lightened flywheel with a v8 clutch, can the fingers on the pressure plate be adjusted? The one I'm about to put in, the fingers are not the same distance from the flywheel. I don't see where they can be adjusted. Am I looking at this wrong? I do not want clutch chatter when I put this all back together. Thanks for the help.
rusted is offline   Reply With Quote
Old 10-26-2016, 04:11 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: pressure plate fingers
New chinese pressure plate? The ones I have seen don't have the adjustment the originals have
Old 10-26-2016, 06:53 PM   #3
rusted
So is there a way to get the fingers all at an equal distance?
Old 10-26-2016, 09:40 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
A disc that is not the same thickness in different places can move the levers uneven too, to adjust you need spacers that are exactly the same thickness to take the place of the disc
perhaps there are shims between the release lever yoke and the cover---or it needs some(under the 3 bolts)between the yoke and the cover----but you need a method of clamping the springs to take the pressure off the yokes
Old 10-26-2016, 10:24 PM   #5
tbirdtbird
send it back
'31 180A
tbirdtbird is offline   Reply With Quote
