Old 10-08-2016, 03:10 PM   #1
DD931
DD931's Avatar
Default Loadomatic spring adjustment
I'm rebuilding a distributor for my '48 F-1 with an "H" engine which uses a Loadomatic distributor. I'm ready to run it on my Allen Synchrograph and want to adjust/check the breaker plate springs. The Ford Shop Manual to apply 0.26 inches of vacuum and adjust the light spring to result in 1 3/4 degrees advancement at 400 RPM and the heavy spring at 1.4 inches of vacuum for 6 1/4 degrees of advancement at 1000 RPM.
My problem: I can't read these small/low levels of vacuum with a regular vacuum gage that ranges from 0 to 25+ inches. I'm looking for suggestions on how to proceed. Am I looking at this wrong somehow? Bubba - are you there?
DD931 is offline   Reply With Quote
Old 10-08-2016, 03:24 PM   #2
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: Loadomatic spring adjustment
Just use the low vacuum and adjust eccentric pin to get approx 2 degrees and then 1.5-2 vacuum to get the 6-7 degrees . that will give you approx 18 degrees of vac advance.....close enough...........
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 10-08-2016, 06:22 PM   #3
DD931
DD931's Avatar
That's sort of what I figured, but having expert advice makes all the difference!! Thanks!!
