Hey guys and gals,
I could use your help identifying these early Ford juice brakes. Any help is greatly appreciated. Thanks! -Jeremy
Atomic Batteries to Power... Turbines to Speed... |
Hi these are 1940-41 and someone has drilled holes for another bolt pattern, as the other BILL stated someone has replace the anchor bolts with regular type bolts.
BILL |
The hubs look odd. A 1940 O1A hub has raised bosses for the studs. The bosses had a raised side and the studs were flat on one side. The hubs may be F1 or something off the wall. A side view would help. I agree on the drums and backing plates.
#5 | |
Here's some more pictures of the hub. The hub does not seem to fit the 1940 spindles that I have. So perhaps they are off something else??? -Jeremy
Mart. |
If they are F1 they would require a different inside bearing.
Mart is right. They are something odd. They are NOT F1 or F-100. Maybe later pass. car?
Pickups stayed 5 lug on 5 1/2" circle for a long time.
Backing plates are 39-42 design.
I just had my 40 rear backing plates and drums off. Mine looked the same as those pictured with the exception of the e-brake stuff and the modern anchor point bolts shown. My drums looked the same but they didn't have the larger lug holes in them. Not much help but that's all I have.
35 Ford Cabriolet 56 Chevy Pickup 63 VW Bug Empty wallet |
Using these 39-48 Hydrolic brakes on a Model A or other light car, works pretty good with a marginal safety factor. However, using them on a later heave yer cay is not beneficial for today's traffic. Up grade to a disk brake setup.
#13 |
Thanks everyone for all your help!!
I really appreciated it. I doubled checked the bearing numbers as recommended by Mart. They were correct for that spindle. I took a bit of emery cloth and polished up the spindles a bit and the hub now fits! -Jeremy
#14 |
Looking at the "X" marks adjacent to the holes with studs, it's appears that the hub flange has been marked for re-drilling to the larger pattern, suggesting that these hubs perhaps were not originally 5 x 5-1/2". But for the life of me, I can't think of any drums/hubs that will fit a Ford spindle (especially 12") that had a smaller than 5-1/2" bolt circle. DD
#15 |
I tried measuring the picture and did some math on the original bolt circle. The crude answer was 4.40". It could be a Ford passenger hub as 4.50" is close to what I estimated.
#16 |
I had a Mullins trailer. It originally came with 6 lug Chevy hubs and wheels. 40 Ford hubs fit right on like stock and allowed the use of Ford 5 lug wheels. I think a lot of early hubs used the same bearings.
#17 | |
The other holes measure 5" -Jeremy
