Old 09-02-2016, 03:20 PM   #1
Henry/Kokomo
Henry/Kokomo's Avatar
Default Steering Wheel Repair
I'm working on rebuilding steering components for my '30 AV8 Roadster. I have a 1930-something Ford wheel in pretty good shape with the exception of two cracks in the rim where the original material has apparently shrunk and pulled apart. Question: Is there any advantage to buying one of the commercial "steering wheel restoration" kits versus filling the cracks with JB Weld or an equivalent product?
Thanks in advance for all input and advice
Henry
Henry/Kokomo is offline   Reply With Quote
Old 09-02-2016, 03:42 PM   #2
32Bee
Default Re: Steering Wheel Repair
PC7 is a single stage (two part) filler that is best IMO for steering wheel repair.
Unlike fiberglass products, it doesn't set immediately so there's plenty of time to
shape your repaired area. Let it dry over night and sand to finish contour. When
I saved my 32 wheel I sealed the whole wheel, after repairs, with PPG epoxy
primer then painted the whole wheel with a flattened out black enamel. Came out
like a million bucks.
Good Luck,
Peter
32Bee is offline   Reply With Quote
Old 09-02-2016, 07:14 PM   #3
adileo
adileo's Avatar
I second pc7 I refurbished my 39 banjo steering wheel. I used a dremel tool to widen cracks then filled with pc7. Sanded to fine grit, primed, painted then clear coated. Came out great.
adileo is offline   Reply With Quote
Old 09-02-2016, 07:33 PM   #4
V12Bill
V12Bill's Avatar
Don't use JB Weld to repair your steering wheel. I did and in 6 months the JB Weld shrank showing each repair.
V12Bill is offline   Reply With Quote
Old 09-02-2016, 07:39 PM   #5
luvmyclassics
luvmyclassics's Avatar
I used pc7 and my steering wheel looks great. Widen the cracks with a dremel and fill with the putty.
luvmyclassics is offline   Reply With Quote
Old 09-02-2016, 07:50 PM   #6
-Big Al-
-Big Al-'s Avatar
Use marine tex.
Al.
-Big Al- is online now   Reply With Quote
Old 09-02-2016, 07:53 PM   #7
cmbrucew
cmbrucew's Avatar
Used JBWeld on two Ford wheels, one year on one and two on the other. Both doing well in So Cal.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 09-02-2016, 08:35 PM   #8
Lawson Cox
Lawson Cox's Avatar
Repaired my 36 Banjo with PC 7 about 20 years ago, and it still looks great. Painted it gloss black alkyd enamel with a hardener.
Old 09-02-2016, 08:52 PM   #9
v8fordman
v8fordman's Avatar
I have used PC7 and Marinetex with excellent results from both. Never used JB Weld, but used fiberglass once and cracks reappeared . I use PC7 exclusively now. It is easy to sand and hasn't shrunk yet.
v8fordman is online now   Reply With Quote
Old 09-03-2016, 08:07 AM   #10
Dyna
Dyna's Avatar
My two cents. I did my steering wheel with a product called "Magic Sculpt". It is an epoxy putty used by sculptors and taxidermists. I bought mine from a taxidermy supplier. Can work with it wet and sets very hard. I had lots of cracks, big and small in my steering wheel. Was very happy with the results. I also used it to make bezels for the speedometer and clock and speaker hole cover of my dash.
Dyna is offline   Reply With Quote
Old 09-03-2016, 07:20 PM   #11
Rand
Rand's Avatar
Where do you guys buy your PC7?
Randy
Rand is offline   Reply With Quote
Old 09-03-2016, 07:31 PM   #12
adileo
adileo's Avatar
I got pc7 at Ace hardware.
Old 09-04-2016, 05:22 AM   #13
oldandtired
There is an excellent product named Dolphin Glaze. It comes with a hardener, will fill the cracks with no issues, does not shrink, is easy to sand, feathers well, and will take pretty much any primer or paint. It is made by U-Pol. You can use it on the steering wheel, metal to fill pits prior to priming, plastic, or wood. I have some cans of PC-7 sitting on the shelf never opened because after I bought them a friend with a body shop introduced me to Dolphin Glaze. I suspect PC-7 works just fine as well, but the Dolphin Glaze will set very quickly and is finishable very quickly.
oldandtired is offline   Reply With Quote
Old 09-04-2016, 05:59 AM   #14
37coop
37coop's Avatar
The banjo wheel on my 39 coupe was bad including missing bits down to the wire and cracks everywhere,repaired it with JB weld around 12 years ago,a long laborious job but it still looks excellent,just started driving it after a looong restoration so I guess the test is using it,over the pond here I have never heard of the alternatives.
I painted it with etching primer,a couple of light coats of spray putty and color then clear (lacquer )
37coop is offline   Reply With Quote
Old 09-05-2016, 09:10 AM   #15
Henry/Kokomo
Thanks for all the responses and advice. I really appreciate the input.
Henry
Old 09-05-2016, 09:30 AM   #16
JSeery
JSeery's Avatar
I have ordered PC-7 online (but then I order a lot of stuff online).
