Old 08-31-2016, 09:46 PM   #1
elwood
elwood's Avatar
Default Starter assembly question
Hey guys, wile replacing a broken spring, somehow I let the armature slide out of the brushes, I was looking for the easy way, if there is one, to get the armature back in the brushed ..
Thanks..
elwood is offline   Reply With Quote
Old 08-31-2016, 10:15 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Starter assembly question
For a long time I used an old bicycle spoke as a hook to lift the springs ----pull the brush out, put together, lift the spring, fit the brush into the holder, release the spring--make sure the end of the spring is centered on the brush so it wears even
Old 08-31-2016, 11:21 PM   #3
GB SISSON
GB SISSON's Avatar
After a few too many of those 'slide apart' mishaps I always put nuts on the end of the two long bolts as soon as I pull the starter.
Old 08-31-2016, 11:25 PM   #4
elwood
elwood's Avatar
Yea me too most times ...
Old 09-01-2016, 12:43 AM   #5
flatheadfan
flatheadfan's Avatar
This is not as big of an crisis as it looks. Remove the armature leaving the brush plate attached. Take off the band. Reach down inside the housing and push a brush up into its' holder. This pushes the two connecting copper cables up and above the starter housing. Place a screw driver (anything will do), under the copper wire loupe to hold the brush up. Repeat for the remaining three. Place the armature back in the starter housing and remove each screwdriver letting the brushes down to the armature. Done.
Hope this helps.
Tom
flatheadfan is offline   Reply With Quote
