When Ford did introduce an oil filter it was the bypass style, which meant only a portion of the oil was filtered. Oil was delivered to the filter from a boss at the back of the block where the oil pressure gauge sender was located. From the filter oil was returned to the pan. A simple arrangement, it’s always been said that 10 percent of the engine’s oil passes through this style filter, which Joe Abbin’s recent testing confirmed (see his sidebar on page 83 for more information). Sidebar Information: How much oil does the Ford Flathead oil pump circulate and how much gets filtered? The stock Flathead oil pump is a positive displacement gear type, capable of circulating about 15 quarts per minute under ideal conditions when the engine is spinning at 2,000 rpm (the high-volume version pumps approximately 20 percent more). A recent test at Roadrunner Engineering demonstrated that a stock ’46-53 oil filter with restrictor flows about a quart and a half of oil per minute through a clean filter under meaningful conditions of oil pressure (55 psi), temperature (180 degrees F), and viscosity (15W-40). This means that about 10 percent of the oil pumped by the stock pump goes through the filter under these conditions and the rest goes unfiltered to the engine. Therefore, under these same conditions, I estimate that all the oil in a 5- or 6-quart system is filtered in less than five minutes at highway speeds. Not bad and certainly worthwhile! Last edited by JSeery; 08-29-2016 at 10:20 AM. |
