Old 08-15-2016, 12:03 PM   #12
Ronnie
Ronnie's Avatar
Default Re: Piston rings for a 221 c.i ?
Originally Posted by 36tudordeluxe View Post
This engine had less than 500 miles on it since being rebuilt years ago by me but always suffered from low compression on all cylinders. I've replaced it with a "warmed" over 8BA. After disassembly am thinking maybe it was that the valves (adjustable) weren't adjusted properly. If you look at the cylinder in the picture you can still see the cross hatch pattern from the original honing operation. There was no ridge at the tops of the cylinders either so am hoping the cylinders are useable as is. The engine is out of the car and on a test stand rather than an engine stand, completely disassembled but with the crank still in it. My intentions are to sell it once the problem is solved.
I would not really call that an acceptable cyl for new rings.Having said that it should be de glazed at the least.No mention if there is any taper?I also would use a flex hone for that operation as they are quick and easy compared to a 3 legged hone for de glazing.If you are close to a machine shop see if they will lend you one as the flex hone is probably around the 50.00 mark.Offer to give them some money and leave a deposit until you return.It also appears it was ridge reamed in a previous tear down.Your engine your rules.Just sayin.
R
Ronnie is offline   Reply With Quote
