Old 08-05-2016, 06:37 AM   #21
JSeery
JSeery's Avatar
Default Re: Ford 1950 ring and pinion?
Originally Posted by Cheaterpete View Post
For your information gas cost 5.8$ a gallon here....
Where do you live! I thought I was being generous at $3, current pump prices here are under $2! And with local discounts it is often around $1.75.
Old 08-05-2016, 07:33 AM   #22
Cheaterpete
France/Switzerland in Europe
Cheaterpete is offline   Reply With Quote
Old 08-05-2016, 08:09 AM   #23
JSeery
JSeery's Avatar
Got to love those gas prices!! I feel your pain.
Old 08-05-2016, 08:27 AM   #24
Cheaterpete
It is terrible... and getting worse every year, it kills our hobby
Old 08-05-2016, 09:24 AM   #25
Ross F-1
Ross F-1's Avatar
What rear end do the cars use? Just recently 3.54 gearsets for the 48-50 trucks that use the Dana 41 have become available. All said and done it's not a cheap alternative, unless you can set up the gears yourself, but it may be cheaper than finding an OD trans and all the bits and pieces. Of course, a good used modern axle is even cheaper.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 08-05-2016, 09:34 AM   #26
JSeery
JSeery's Avatar
The problem with that is it only makes less than 200 RPM difference. Not much gain for the cost and effort.
Old 08-05-2016, 09:54 AM   #27
donald1950
Cheater Pete, i bought one of the timing tools from you. i have done a T-5 in a 50 and can send pictures of all the addaptors i made to use stock clutch linkage and what all is involved, driveshaft and otherwise....... Dawn
contact me at [email protected]
donald1950 is offline   Reply With Quote
Old 08-05-2016, 10:03 AM   #28
51 MERC-CT
51 MERC-CT's Avatar
Assuming that with whatever change you make (transmission, gear change or overdrive ) you get 15% better gas mileage.(and that's a stretch)
At 87¢ a gallon. Divide that into what you expect to pay for the modifications.
That should give you the number of gallons that you would have to burn before you get to the break even point. Something to think about.
Old 08-05-2016, 12:36 PM   #29
JSeery
JSeery's Avatar
I'm a big T5 fan as well, I have never work with one on an 8ba engine, but my understanding is they can be fairly easy to mod. Think Ol Ron has some experience on the later models.
Old 08-05-2016, 02:19 PM   #30
rotorwrench
rotorwrench's Avatar
It may not affect you Cheaterpete, but I heard a news snip it that Paris was banning older cars from being driven on the week days for air pollution reasons. That is some crazy stuff there. Surely there aren't too many de chevaux cars still running around or maybe some old Trabant 2-stroker cars from Eastern Europe?
Old 08-05-2016, 02:45 PM   #31
TomT/Williamsburg
TomT/Williamsburg's Avatar
Hey Pete, how are you doing? That body should be arriving soon I am thinking ....
While you are looking for an overdrive rear, here's a thought. Presently with your car at 2500 rpm you are doing about 56 mph. Now, if you could stuff a 32" diameter 16" tire like a 235/85-R16 at 2500 rpm you would be going 63 mph, at 2800 71 mph. A lot less rpm at greater speeds for the highways ....
That's a fairly easy way to gain some rpm and stay in the 22-2800 rpm range where I usually run and is really a sweet rpm range for a flattie. The engine will love it and you will still have plenty of pep going up hills ....
Just a thought .....
TomT/Williamsburg is offline   Reply With Quote
Old 08-06-2016, 07:32 AM   #32
krackerjack1951
krackerjack1951's Avatar
where are you located..find an O/D trans..i have one in NC near charlotte..buyer be aware of the no it allll nobodys..
krackerjack1951 is offline   Reply With Quote
