Old 07-31-2016, 08:56 PM   #2
Pat/Ohio
Pat/Ohio's Avatar
Default Re: 32 Brake light switch/emergency brake?
Bruce, I had the same problem with my Model B roadster a few years back. I believe the cure is to adjust your brake linkage. I had too much travel at the emergency brake lever, which allowed the brake light switch to engage. It's been a while, but I believe that is what I did. Good luck, Pat
Pat/Ohio is offline   Reply With Quote
