Old 07-17-2016, 03:48 PM   #4
chucksue
Default Re: rear axle seals
No the ones I found are without a flange. When you drive them in there is no way to remove them without separating the rear housing. The good thing there is enough room to install several of these. I put two in each side.
chucksue is offline   Reply With Quote
