Old 07-16-2016, 09:03 PM   #1
skidmarks
skidmarks's Avatar
Default 32 ford coupe rumble seat question
On a 32 ford 5 window. The car started out life as a trunk model and then changed to a rumble seat. Now it's going back to a trunk model. Lucky all the trunk hardware was laying loose in the floor.
Question is. The braces were the rumble seat hinges mount. The holes are booged up and I am going to repair them. From the factory were there no holes in these braces for trunk model cars?
skidmarks is offline   Reply With Quote
Old 07-16-2016, 10:15 PM   #2
DavidG
DavidG's Avatar
Default Re: 32 ford coupe rumble seat question
The vertical strainers (braces) were identical for both rumble seat and trunk versions of the '32 standard coupe.
Old 07-16-2016, 10:27 PM   #3
skidmarks
skidmarks's Avatar
The ones in the car I have ,The holes are large and odd shaped. I will post a picture tomorrow. Theye don't appear to be something I would think was original
Old 07-17-2016, 05:35 AM   #4
DavidG
DavidG's Avatar
They were originally neither large nor in any shape other than round.
Old 07-17-2016, 12:06 PM   #5
skidmarks
skidmarks's Avatar
Here is a before and after. Now does it get a correct size and location put back into it?
Old 07-17-2016, 12:11 PM   #6
skidmarks
skidmarks's Avatar
Also this is where the latch for the rumble lid was. Do these two holes stay as is for a trunk model or should they be welded shut.
Obviously the outside hole for the rumble lid gets welded shut but does the inside hole stay or should it be filled also.
Lucky enough when this was done the previous owner (s) never filled the holes for the trunk handle.
Nice thing is that it's all rust free
Old 07-17-2016, 01:51 PM   #7
DavidG
DavidG's Avatar
Those two holes remain (see photo) and those on the lid for the latch and handle all should be filled, including the slot for the latch tongue and the two holes that bookend the slot to attach the latch.
Old 07-17-2016, 03:09 PM   #8
TonyM
TonyM's Avatar
Thank you.
There is a special place in Ford Heaven for you.
Save the Trunk Coupes.
TonyM is offline   Reply With Quote
Old 07-17-2016, 03:15 PM   #9
34pickup
34pickup's Avatar
My coupe was also converted to a rumble seat by a previous owner and I had to put it back to a trunk. You will need this white panel for the lid to latch on to when you put the hinges back on the top.
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 07-17-2016, 03:39 PM   #10
skidmarks
skidmarks's Avatar
Lucky enough it came with all the original hardware including that panel.
