Old 07-01-2016, 09:35 PM   #12
banjoQ
banjoQ's Avatar
Default Re: 37 Swing out windshield
Thanks Mark for the reply. Sounds like you have to commit to this before you start. Your description sounds like the old seal will be destroyed getting it open.As for the bead in the frame, would this be best done with windshield removed altogether? Your explanation sounds like you are removing it while still mounted to the car. Just thinking it through. Thanks again.
banjoQ is offline   Reply With Quote
