Bruce, The only part that is moveable here is the position of the spider on the four flats on the bottom of the horn rod. Its in the incorrect position so needs moving around on the flat one position. Your description of the positions seems not quite correct. Make sure the Bakelite switch plate is located correctly in the notch of the switch housing, but it only can normally go one way. Regards, Kevin.
