Old 06-22-2016, 08:29 PM   #1
Bruce in southern OH
Bruce in southern OH's Avatar
Default 36 Steer column electrical problem
Drove the 36 yesterday evening, have not drove after dark this year and I found that I had a engine stall problem. The motor would start back up but something was just not right. I was showing a man the head lights before I headed home to find out which position was high and low beam and the Horn would sound as I turned the light switch. Left lights on and traveled home, slow down and motor would stop and I would place in gear quickly and start motor and go on. Checked car this morning and no power on the on/off column switch. Checked the shut off switch and it was hot but not the panel under dash. Rotated the light switch and no dash lights. When I checked again I had power and I started engine. I can turn light switch and kill all power/engine. Move light switch back and forth several times and have power back again, anyone have this problem or thoughts about electrical connections at end of column?? thanks Bruce
Bruce in southern OH is offline   Reply With Quote
