#21 | |
In my simple mind, if I have 0.010" runout at the 10" semi-circle where the housing bolts to the block and I extend that runout to the 15" diameter of the flywheel housing, and my flywheel housing is "perfect" between the two faces, that's 0.015" I'm trying to correct and the best I can achieve is 0.013". I can't go past "no shims" on the driver's side to try and pull down the high side measurement and increasing shims on the passenger side, over 0.013 begins to worsen the measurement. |
#22 |
Robert,
I suspect that you have a bad align bore job. In your first post, you said that when the dial indicator base was on the crankshaft flange and the indicator swept the machined surface at the rear of the block 180 degrees, the run out was .010 in. This is an indication that your crankshaft is not parallel to the camshaft. Remove the crank and cam shafts and measure the distance between crank and cam bearings at the front and rear of the cylinder block. This problem cannot be fixed by shimming the flywheel housing. |
#23 |
This is possible.
I would repeat that measurement. Also possible is that the bore is aligned properly but the flange is not true
'31 180A |
#24 |
#25 | |
Guys, this always works, it is in you minds where were having trouble, but after you do it, it will become clear. Herm. |
#26 | |
#27 |
Epitaph......Many thanks to all for your suggestions and advice. I was totally unsuccessful with ANY shim combination or differential between shim stacks in getting the measurements any closer than a 0.013 spread. So this morning, I bolted the flywheel housing to a 1" thick slab of aluminum plate and milled it starting at zero on the passenger side and cutting across to the driver's side where 0.005 was removed, with 0.0025 removed at the 12 O clock position between the tabs. Remounted the housing, and made a quick check of the 3 and 9 position and they were within .005. Played a bit with shims and wound up with 0 at 12 oclock, 0 at 3 oclock, .003 at 6 oclock, and .004 at 9. That I can easily live with and the only downside is that if/when the crank is ever straightened in the block with a new babbitt pour, I'll probably have to go back and take .005 off the passenger side of the housing to once again true its front and back faces. I believe my inability to correct the misalignment was the fact that I had the most disparity between readings at the 3 and 9 positions, some .015" total, right where it was bolted to the back of the block....
#28 |
Poor alignment of the crank causes problems at the front of the engine also. Last winter I tried to complete a cash and carry short block, picked up at Turlock from a big name in engine building. Short story is that the line boring of the mains was off (too close to the cam) by a few thousandths. turning it over caused the fiber timing gear to fail. I tried another standard gear and was unable to get it in, too tight. My point is that Dan McEachern was able to supply me with an undersize timing gear that solved the problem. Now I'm soon to address the possible problem of aligning the trans to the crank and the thread has been useful. I had not before heard of an undersize gear but feel lucky that it was available. Good Luck: Fred A
#29 |
Tennsmith if you ever sell the car I am sure you will advise the new owner of what has been done to the FW housing, since no one would ever figure this out
'31 180A |
