03-23-2016, 06:55 AM
#5
Re: Preheating of the engine
Originally Posted by ian Simpson
This is one time I disagree with the Guru of Stuff. If you are starting in very cold weather, it is helpful to have some sort of pre-heat. Back in the day, I used to have a Davey Lamp (safety kerosene lamp) under my vehicles in cold weather. Now I use block heaters. If you are planning in starting the Model A in temperatures colder than freezing you might consider some external heat source. My father-in-law used to throw an old blanket over the motor and tuck a 100 watt trouble light under it.
You're RIGHT, Ian,
I made a DUMB statement!----Here, I'm just sleeping under a sheet & my flowers are BLOOMING!
Bill W.
"THE ASSISTANT GURU OF STUFF"
