Sorry to disagree with Henry, but that is not a good relay to use for 6v systems.
Bosch SPDT 6V 30 amp Relay 0332204001 Used as dimmer relay In 1950 to 1966 VW Also listed as: Merced 0035340245 Porsche PCG61510100 John Deere AR91168 The Bosch Relay is a high quality metal cased relay, but it is fairly expensive, a cheaper alternative is the plastic style such as: Durakool DG85B-8011-96-1006-M1 TE Connectivity / Potter & Brumfield 1432873-1
