Old 10-23-2015, 02:58 PM   #1
30-9
Default Rotella Oil
Hi all
I recall reading on here that Rotella 15 40 was a good oil for our flatheads.
So I was in the auto store today and went over to the Oil area and picked up a bottle. It read it's for diesel motors.
So did I mis-read the post or is Rotella 15 40 diesel oil good in a flatty?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 10-23-2015, 03:01 PM   #2
Alaska Jim
Alaska Jim's Avatar
Default Re: Rotella Oil
In my opinion, no. you did not misread. I use it in My '51 Merc. with a flathead, I also use it in my '30 coupe with a Y-block. it is a very good oil.
Alaska Jim is offline   Reply With Quote
Old 10-23-2015, 03:04 PM   #3
Seth Swoboda
Seth Swoboda's Avatar
Rotella 15w-40 is used in diesel engines and your flathead V8 gasoline engine.
Old 10-23-2015, 03:06 PM   #4
zzlegend
zzlegend's Avatar
Use it both my flatheads and model a. Good choice.
zzlegend is offline   Reply With Quote
Old 10-23-2015, 03:12 PM   #5
Bruce in southern OH
Bruce in southern OH's Avatar
Use in my cars, long talks on here about Zinc or lack of Zinc. Search the Forum and you decide.
Bruce in southern OH is offline   Reply With Quote
Old 10-23-2015, 03:32 PM   #6
30-9
Excellent thanks Gentelmen!!!
Thanks - 30-9
1939, 1940
Old 10-23-2015, 03:35 PM   #7
Ralph Moore
Ralph Moore's Avatar
We use it in all our fleet maintenance of semi's.
Ralph Moore is offline   Reply With Quote
Old 10-23-2015, 03:48 PM   #8
JonC
It's made by Shell, and I use it in my Flatheads and Indian motocycle.
JonC is offline   Reply With Quote
Old 10-23-2015, 06:14 PM   #9
42guy
42guy's Avatar
I have been using it my flathead for 12 years.
42guy is offline   Reply With Quote
Old 10-23-2015, 06:19 PM   #10
Ford Freak
I've used it in various V8 engines up to 1972 . No problems ....
Ford Freak is offline   Reply With Quote
Old 10-23-2015, 06:34 PM   #11
CA Victoria
CA Victoria's Avatar
As stated, lots of info already posted. I found this interesting too.
http://speedtalk.com/forum/viewtopic.php?f=1&t=35836
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 10-23-2015, 07:14 PM   #12
Marv
Marv's Avatar
I do not know this positively, but i was told by a mechanic years ago that you could use diesel motor oil in a gasoline engine but you could not use gasoline engine oil in a diesel.
Marv is offline   Reply With Quote
Old 10-23-2015, 07:14 PM   #13
36coupe
36coupe's Avatar
I use it in my old stuff and high mileage late model stuff
36coupe is offline   Reply With Quote
Old 10-23-2015, 08:03 PM   #14
ronford
I use Rotella oil in my 1940 Coupe per the recommendation of a local flathead specialist.
This week I carried my 1966 Mustang with 289 to Ford Dealer for free oil change that I won as a prize in a recent Mustang Car Show. The dealer recommended Rotella 15W/40
for my car. I agreed. Will see how it performs in the Mustang.
ronford is offline   Reply With Quote
Old 10-23-2015, 09:18 PM   #15
paul2748
paul2748's Avatar
I use Rotella T 15/40 in both of my YBlocks. One has gone from coast to coast twice. No problems. I wish I could say the same for the rear main seal.
ZDDP right up there.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-24-2015, 12:54 PM   #16
LazarusLong
LazarusLong's Avatar
Guys,a word of caution here about using a modern high detergent oil in older engines that were designed to use non-detergent oil. Namely,DO NOT use high-detergent oil in a older engine that has has ran non-detergent oil all it's life and has never been rebuilt. If you do,it will bust loose all the sludge and clog up your filter and your oil passages. The result will be your oil pressure will drop to zero. If you are lucky,you will notice this before bad things happen and will stop the engine,drain it,remove and replace the oil filter,fill the engine with 30 or 40 wt non-detergent oil,and then run it for a while at home until you see the oil pressure start to drop again,and then replace the oil filter again and add a quart of non-detergent 30 or 40 wt oil. Repeat as necessary.
By all means use it if you have a engine that has been hot tanked and rebuilt. It's much better oil.
LazarusLong is offline   Reply With Quote
Old 10-24-2015, 02:52 PM   #17
JT FORD
JT FORD's Avatar
I wouldn't put non detergent oil in any motor........
JT FORD is offline   Reply With Quote
Old 10-24-2015, 02:55 PM   #18
G.M.
Read this before wasting money on Rotella. I use Valvoline
Cummins Blue in all of my diesels and some off the flatheads.
This is much better than Rotella I like the Molly as well as the
Zink. G.M.
www.fordcollector.com
Old 10-24-2015, 03:25 PM   #19
G.M.
I had problems uploading this file but I think I got it. G.M.
Old 10-24-2015, 03:41 PM   #20
Bored&Stroked
Bored&Stroked's Avatar
Great article! Thanks for sharing it.
