Old 09-25-2015, 12:13 PM   #1
Dtolson
Dtolson's Avatar
Question Rope seal
Do you have to drop the oil pan to change the front rope seal or can you get to it by removing the timing gear cover only?
Big D
Dtolson is offline   Reply With Quote
Old 09-25-2015, 12:25 PM   #2
H. L. Chauvin
Default Re: Rope seal
Rope seal is in (2) pieces, one in timing cover, other in oil pan.
Remove timing cover to replace top half; remove oil pan to replace bottom half .
H. L. Chauvin is offline   Reply With Quote
Old 09-25-2015, 05:04 PM   #3
colin1928
colin1928's Avatar
It is possible to do it with the timing cover and the pulley remover but it hard to pack it in to the sump groove tightly enough while the crankshaft still there
can be done just takes time
colin1928 is offline   Reply With Quote
Old 09-25-2015, 07:12 PM   #4
Dtolson
Dtolson's Avatar
Thanks for the reply. I would rather not remove the pan since the leak is only in the front at the crank.
Big D
Old 09-25-2015, 08:09 PM   #5
andyfresno
OK guys - -don't shoot me - -this is just my opinion
It's easier to drop the pan and do it right.
I'd bet I'd be done before you got the old one out.
Again,, just my opinion.
andyfresno is offline   Reply With Quote
Old 09-25-2015, 08:28 PM   #6
Dtolson
Dtolson's Avatar
Sounds like the best plan. Just thought I'd ask. Thanks guys.
Big D
Old 09-26-2015, 03:12 AM   #7
H. L. Chauvin
Hi Big D,
Not trying to be funny, but in agreeing with the sincere advice in response #5 ...... you can also wipe yourself "with" your tuxedo on ..... it just takes far more time.
Then later when you get back to the reception, and get down to reality, removing your tux trousers would have taken far less time and would appear to have made as much sense as removing your oil pan to do it correctly.
Comparisons sometimes helps one to think differently and make different decisions.
Hope this helps.
Old 09-26-2015, 08:16 AM   #8
andyfresno
What's a tuxedo?
Old 09-26-2015, 08:18 AM   #9
George Miller
George Miller's Avatar
Just pull the pan and do it right. That way you will only have to do it once. It really is not that hard to do.
George Miller is offline   Reply With Quote
Old 09-26-2015, 10:20 AM   #10
katy
katy's Avatar
You may be able to do it by loosening all the pan bolts and just dropping the front of the pan, but then, if you're going that far you may as well just take the pan right off.
Don't forget to soak the new seals in oil for an hour or more before installing them.
Old 09-28-2015, 02:38 PM   #11
Dtolson
Dtolson's Avatar
Thanks H.L. Great advise and I appreciate the tuxedo comparison !
Big D
