Old 09-15-2015, 07:22 AM   #1
waxhead
waxhead's Avatar
Default Installing a Mitchell Overdrive
I am planning on installing a Mitchell Overdrive in the future. Are there any other parts people recommend replacing at the time of installation that are not included with the overdrive?? It is not very easy or fast for me to get Model A parts where I live, so I want to make sure I have everything ready when I get around to doing the installation. Any recommendations appreciated. Thanks
waxhead is offline   Reply With Quote
Old 09-15-2015, 08:46 AM   #2
larrys40
Default Re: Installing a Mitchell Overdrive
make sure you have a u-joint gasket kit.... and your U-joint is good... and of course if your rear axle needs rebuilding at the same time that it is done. If it is good then great. I would never put a Mitchell in a rear axle that has NOT been rebuilt properly.
Of course brakes should also be paramount and up to snuff. Other than that Mitchell supplies everything for the conversion in their package. They have it honed down well and I can promise you will be pleased. It makes it a new car ( or truck).
Larry Shepard
larrys40 is offline   Reply With Quote
Old 09-15-2015, 09:08 AM   #3
waxhead
waxhead's Avatar
Larry, I recently upgraded the brakes, new cast iron drums, brake shoes, Ted's floater kit etc
I also recently did the rear axle when I installed a new gear set (3.54:1). I have a freshly built touring engine with HC head, counterbalanced crank etc so I am confident the 26% over drive and 3.54:1 gears should work well from what I have read on here.
I might grab a new u-joint just in-case. Thanks for the response. Any other suggestions??
Old 09-15-2015, 09:22 AM   #4
Benson
Pinion gear puller ...
Mitchell used to rent them.
Old 09-15-2015, 10:08 AM   #5
CarlG
CarlG's Avatar
Mitchell has re-designed their pinion puller and now sell them fairly reasonable. Absolutely worth having.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-15-2015, 11:12 AM   #6
Brentwood Bob
tall jack stands to get the rear end up in the air.
Bob
Brentwood Bob is offline   Reply With Quote
Old 09-15-2015, 11:26 AM   #7
Tom Endy
Tom Endy's Avatar
For reasons of safety you should acquire and use a proper spring spreader.
Tom Endy
Old 09-15-2015, 05:18 PM   #8
apbright
apbright's Avatar
I am an amateur mechanic, and have installed two Mitchell Overdrive's (and man, do I love them, but that's another story).
An obvious thing to replace would be the clutch disk, but that requires removing the transmission, the bell housing, and the pressure plate, none of which are necessary for installing the overdrive (you're just near that working area when doing so).
You may wish to replace the main speedometer cable, in case your original is rough or worn.
For the first Mitchell I installed, I fashioned a pinion puller from a small, thick piece of sheet metal, and damaged the pinion bearing cup doing so. The second time I used a pinion puller tool I bought from Snyder's (made by Mitchell, I believe), and everything went much more smoothly and quickly. This is a ~$80 investment I recommend.
Beyond that, to quote 'Yes, Prime Minister,' "There are many things you can do, but nothing else you must do. You're the boss!"
apbright is offline   Reply With Quote
Old 09-15-2015, 06:06 PM   #9
CarlG
CarlG's Avatar
Originally Posted by apbright View Post
... The second time I used a pinion puller tool I bought from Snyder's (made by Mitchell, I believe), ... This is a ~$80 investment I recommend...
I have both a pinion puller I bought from Snyder's and one I bought from Mitchell. The one from Mitchell is heftier than the one from Snyder's.
Having said that, whatever works for you. The price is about the same for either tool.
Alaskan A's
Old 09-15-2015, 06:39 PM   #10
waxhead
waxhead's Avatar
Thanks to everyone for the input.
Old 09-15-2015, 07:57 PM   #11
sphanna
sphanna's Avatar
The snyder pinion puller I got from Snyders was not strong enough to pull the pinion. I had to drill and tap 3 more holes for three more bolts to keep from bending the tool.
Steve Hanna, Polk City, IA
sphanna is offline   Reply With Quote
Old 09-15-2015, 08:17 PM   #12
RUNNERBUN
RUNNERBUN's Avatar
Larry Shepard
I recently installed a Mitchell Overdrive. The universal Gasket set and gasket for pinion end came in the box with my overdrive. You don't get the actual universal joint.
Adjust your points with gentle blows of a 2 pound hammer
RUNNERBUN is offline   Reply With Quote
Old 09-15-2015, 09:43 PM   #13
waxhead
waxhead's Avatar
http://www.snydersantiqueauto.com/pi...tallation-tool
I think I might grab the one above. Appears to be better than the one below.
I am guessing the one below is the one people have said is not up to the task.
http://www.snydersantiqueauto.com/pinion-puller
Old 09-15-2015, 11:50 PM   #14
Brentwood Bob
Install kit that comes with the overdrive includes a speedometer cable.
The more elaborate pinion puller looks like the mitchell I have.
You might ask about the correct mount for your pickup the clearance from the top of the shift arm casting has to clear the floorboard. Mitchell has a modified casting.
Bob
Old 09-16-2015, 12:32 AM   #15
waxhead
waxhead's Avatar
Bob, thanks for the info on the shift arm casting.
Old 09-16-2015, 10:43 AM   #16
Brentwood Bob
Mitchell is just 4 hours north of me, so it was easy to exchange the mounting.
Bob
Old 09-16-2015, 10:57 AM   #17
sphanna
sphanna's Avatar
Waxhead
You are correct. The second one in your post is not up to the task.
Old 09-16-2015, 07:50 PM   #18
Stew
Stew's Avatar
I also just installed a Mitchell overdrive in my 31 Tudor. I built a rolling mount with two connected dollies to support the rear axel and the front of the torque tube. There are several versions I have seen. This dollie makes the installation much easier.
Also you need two thin wrenches to set the preload of the pinion bearing.
Snyders part # A-4634-T
Regards,
Stew
Stew is offline   Reply With Quote
Old 09-16-2015, 08:00 PM   #19
pat in Santa Cruz
pat in Santa Cruz's Avatar
you might want a rubber bellows to slip over your new shift lever
pat in Santa Cruz is offline   Reply With Quote
Old 09-16-2015, 11:11 PM   #20
Hoogah
Hoogah's Avatar
You might consider replacing your rear bushes when you detach the spring. Mine were worn and I had to destroy one of them to remove it.
X2 on all the comments on getting the sturdiest puller you can. The Snyder one that I borrowed bent during the process.
Enjoy your Mitchell. You'll join the "Aah!" Club the first time you slip it into overdrive! Overdrive 2nd is also a great ratio.
Hoogah is offline   Reply With Quote
