Old 09-09-2015, 03:02 PM   #1
Curt Campbell
Curt Campbell's Avatar
Default Glycol for Painting Inside of Engine
Any recommendations on whether or not use Glyptol or similar coating to coat insides of engine etc? I know Eastwood sells it.
Thanks in advance.
Curt Campbell is offline   Reply With Quote
Old 09-09-2015, 03:06 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: Glycol for Painting Inside of Engine
Try doing a search. This has been discussed previously. Some say yes, some say no.
Paul in CT
Old 09-09-2015, 03:25 PM   #3
Dollar Bill
Dollar Bill's Avatar
Adhesion is the greatest concern. You would need to bake the block in order to remove all the oil that has permeated the pores of the casting. Coating the lifter valley with Glyptal was once a racer trick to improve oil return to the sump. Hard to justify the delamination risk for a Model A.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 09-09-2015, 03:37 PM   #4
Fullraceflathead
Fullraceflathead's Avatar
Redi strip chemical stripping is what I've always used when building engines.
When the casting is spotless and only then, are ready to paint.
If you have any doubts about it being clean enough, don't paint it.
The last thing you want is paint peeling off in strips and plugging up the pump.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 09-09-2015, 03:46 PM   #5
Lona
Lona's Avatar
My '31 roadster with a '30 engine has a brick color inside the engine block and the valve chamber with no chipping or delamination anywhere. I assume it is Glyptol but can't be sure. I don't think this was done at the factory so it must have been applied when the engine was rebuilt some years ago. My understanding is that it helps prevent seepage of oil through the pores in the metal casting and helps oil move throughout the system. I agree that unless you did a really thorough cleaning, you would be better off just going with the bare casting. Why take the chance of ending up with poor adhesion and paint chips floating around inside your engine?
Glen
'31 Model A Deluxe Roadster
'35 Packard Convertible Sedan
'88 Pontiac Fiero GT
'36 Auburn Boattail Speedster replica
Lona is offline   Reply With Quote
Old 09-09-2015, 04:21 PM   #6
CarlG
CarlG's Avatar
Painting anything with Glycol would be a challenge.
That being said, my engine was painted with a red substance I assume is Glyptol. As far as I can tell, it has held up really well. Can't say that about the rest of the engine, but then that's another story altogether.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 09-09-2015, 06:24 PM   #7
J and M Machine
Location: 40 Mt.Vickery Rd. Southborough,MA 508-460-0733
Thanks in advance.
No because you'll never get it clean enough for the paint to adhere.
Here are two perfect examples. One Model A; with paint coming off in lifter gallery and other Pontiac engine; with paint chips plugging the oil pump screen.
J and M Machine is offline   Reply With Quote
Old 09-09-2015, 06:47 PM   #8
Ron in Quincy
Ron in Quincy's Avatar
I use a red epoxy insulating enamel for interior of engines, armatures in starters and generators, inside distributors, and inside Zenith and Holley Carburetors; it penerates, coats and seals in one operation; it is oil and gas resistant; when wet 1200V when dry 2100V. It comes in a spray can so makes it very easy to use.
I learned of this product from a business here in Quincy, CA, Holloway Engineering who rebuilds airplane Radial engines, and is noted for his quality all over the world; the interior of some of these engine cases were original painted with Glyptol, Holloway uses this epoxy on the interior cases of these rebuilt engines, also uses it when rebuilding starters and other electrical items.
The product is available from: Aervoe Industries Inc. in Gardnerville, Nevada, Some time ago I spoke to Jeff Weaver in Customer Service 1-800-237-0196; the product is 401 Red, you have to buy a case at a time which contains 12ea. 16 oz. spray cans, the cost was $83.25 plus shipping.
Ron Rude
Ron in Quincy is offline   Reply With Quote
Old 09-09-2015, 07:26 PM   #9
leakers
Thanks in advance.
go to the source for info, supply and recommendation.
http://www.glyptal.com/glyptal_home.html
leakers is offline   Reply With Quote
Old 09-09-2015, 08:22 PM   #10
harleytoprock
Adhesion concerns outway any real benifits. Don't do it.
harleytoprock is offline   Reply With Quote
Old 09-09-2015, 08:26 PM   #11
Mitch//pa
yep bigtime
Old 09-09-2015, 09:31 PM   #12
SteveB31
SteveB31's Avatar
We have taken apart three failed engines with that crap completely plugging up the oil pump screen. My vote is NO!!!
Steve @ Bert's
SteveB31 is offline   Reply With Quote
Old 09-09-2015, 10:29 PM   #13
al's28/33
al's28/33's Avatar
why do something like that which was never done originally ?????
ever heard, "If it ain't broke, don't fix it !"......?
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 09-09-2015, 10:39 PM   #14
Dodge
We used to do the inside of race motors as it was supposed to help with oil return and to
seal the inside of the motor. I think it was a passing fancy and a monkey see monkey do.
We only did it to race motors as they were torn down on a regular basis and and we could
check up on it. When done correctly it always stayed on even when the motor was pressure washed on a rebuild. We haven't done this to any motors in almost 20 yrs.
We also don't send the oil down from the heads and lifter valley like we used to.
The oil is sucked out with more stages of the scavenge pump and back to the oil tank.
If it makes you feel good do it....
Dodge is offline   Reply With Quote
Old 09-10-2015, 12:24 AM   #15
Chris Haynes
Chris Haynes's Avatar
My block was hot tanked. Nice clean bare metal. I used spray can Glyptol.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 09-10-2015, 09:56 PM   #16
Curt Campbell
Thanks for the responses guys.
Old 09-11-2015, 12:37 PM   #17
hardtimes
hardtimes's Avatar
I've used it (glyptol) for engine interior coating for years. Never have had a problem....when used PROPERLY ! IMO, any product can be misused and you will get results commensurate with misuse. For instance, an engine block should be hot tanked , then this product applied to a CLEAN surface.
