Old 11-20-2010, 08:39 AM   #1
David W Juliano
Default clock repair/restoration
My 1939 clock needs to be repaired mechanicaly ( I'm guessing the main spring) and cosmeticly. Many vendors advertise clock repairs. Any recommendations based on clock repairs you've had done. Thanks in advance.
David W Juliano is offline   Reply With Quote
Old 11-20-2010, 10:28 AM   #2
Gary in La.
Gary in La.'s Avatar
Default Re: clock repair/restoration
I just had my '46 clock repaired by "THE CLOCK WORKS" in Eagle River,Wi. and was well satisfied. Nice people to deal with and fast service. Ph.# (715) 479-5759. or
www.clockwks.com
Gary in La. is offline   Reply With Quote
Old 11-20-2010, 11:16 AM   #3
B-O-B
B-O-B's Avatar
I had the 57 bird clock worked on by the clock works twice & it still don't work. Looked like a gorilla worked on it. I can't reccommend that outfit. They did refund some monies & said they will call it quits but I'm still out money & a non-op clock.
B-O-B is offline   Reply With Quote
Old 11-20-2010, 10:11 PM   #4
42guy
42guy's Avatar
There is a gentleman that lists on E-Bay. Repairs most type of clocks. Don't know a thing about him. just saw it on E-Bay.
42guy is offline   Reply With Quote
Old 11-21-2010, 07:30 PM   #5
paul2748
paul2748's Avatar
Try www.williamsons.com. They do repair and cosmetics. If you want a quartz movement they can do that. I had two clock converted to quartz by them and both run perfectly.
