#13 |
An easy way to make the pitman arm point straight up is to use a 32-34 steering box with 35-36 internals. If you google my son's (Phil Migliore 29RPU ) car, a black 29 Model A RPU with a Cragar Overhead conversion, you will see the set up I described. Depending on the car you are working on this may work for you.
Early Ford Lock & Key Service http://www.fordbarn.com/forum/showthread.php?t=46583 |
