Old 08-10-2015, 01:51 PM   #1
scicala
scicala's Avatar
Default 50/50 mixture of Acetone and ATF
I have a question...., when using a 50/50 mixture of acetone and ATF as a penetrating oil to loosen stuck parts, can the acetone/ATF mixture be stored in a plastic container, or does it have to be a metal or glass container ?? I never used it before, and not sure if it will attack the plastic.
Anybody know for sure ?
Thanks, Sal
scicala is offline   Reply With Quote
Old 08-10-2015, 01:55 PM   #2
Mart
Mart's Avatar
Default Re: 50/50 mixture of Acetone and ATF
I have had some in one of those plastic flip top squirty drinks bottles runners use. Your results may vary, test with a small quantity first.
Mart.
Old 08-10-2015, 02:06 PM   #3
FortyNiner
FortyNiner's Avatar
I've used it from a plastic pump container without issue.
Old 08-10-2015, 02:21 PM   #4
scicala
scicala's Avatar
Thanks for the quick replies Mart and FortyNiner.
Sal
Old 08-10-2015, 02:41 PM   #5
my4dv8
Perhaps try a small thumb pump type oil can.
my4dv8 is offline   Reply With Quote
Old 08-10-2015, 03:13 PM   #6
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I put a quart of each in a gal paint thinner can, shake it up, then fill a metal squirt can. You have to shake each time you use, it separates. Walt
Old 08-10-2015, 03:17 PM   #7
Tim Ayers
I've used it in both metal and plastic containers without issue. As Walt stated, shake before use. It does work well.
Old 08-10-2015, 03:35 PM   #8
G.M.
I had a 5 gallon metal can of acetone that destroyed the plastic pour spout
on the top of the can from fumes I guess. G.M.
www.fordcollector.com
Old 08-10-2015, 06:03 PM   #9
hotrodA
hotrodA's Avatar
Mixed it in a plastic coffee container, and used a plastic ketchup bottle to squirt into cylinders.
That stuff WORKS!!
hotrodA is offline   Reply With Quote
Old 08-10-2015, 07:10 PM   #10
GB SISSON
GB SISSON's Avatar
Mart.
Nobody has ever accused me of being a 'safety nut', but I'm thinking that to my grandkids that could look a lot like a strawberry-kiwi juice drink. This debate brings up the guy who invented the 'universal solvent'. Unfortunately there was nothing he could keep it in..... And lastly, I have had that mix in a 59ab for 3 months and this afternoon I pulled the timing gear cover and cam gear and plan to haul the engine into my shop and see if it will turn. I have had good luck with it and also mmo and acetone.
Old 08-10-2015, 10:42 PM   #11
scicala
scicala's Avatar
Thanks to everyone for all of the good input.
Sal
Old 08-11-2015, 08:10 AM   #12
BrianCT
BrianCT's Avatar
My experience was that the bottle i chose was attacked. Acetone will dissolve some plastics.
[FONT=Comic Sans MS]
BrianCT is offline   Reply With Quote
Old 08-11-2015, 08:52 AM   #13
Mart
Mart's Avatar
Good point about safety. No youngsters in my garage, though, so didn't cross my mind.
Mart.
Old 08-11-2015, 09:33 AM   #14
itslow
itslow's Avatar
Originally Posted by hotrodA View Post
...used a plastic ketchup bottle to squirt into cylinders.
Likewise, I have a mix in one of the condiment squirt bottles that are sold by Wal-Mart or the like. The acetone not dissolved the plastic.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 05-16-2024, 08:59 AM   #15
jake197000
i had a 4 hp staionary engine with a long time stuck piston i stood it on end fillred yhe cylinder with acetone and put a stick for a wick in it put a couplr propanr torches on it for about 8 hours a nd with a 2 x 4 knocked it out without too much effort had to sleeve it but its been running good for 25 years.it does work
jake197000 is offline   Reply With Quote
Old 05-16-2024, 09:21 AM   #16
Ol' Ron
Ol' Ron's Avatar
A blast from the past. Sure miss Walt.
Gramps
Old 05-16-2024, 10:19 AM   #17
Ray in La Mesa
Glass is best but the acetone tends to evaporate over time so more must be added for each use.
Ray in La Mesa is offline   Reply With Quote
Old 05-16-2024, 10:25 AM   #18
Vics Stuff
Vics Stuff's Avatar
I have always stored my mix in a plastic oil container. I have never had issues with the plastic melting. I keep the cap sealed as to no acetone evaporates. The concoction works great.
Vic
Vics Stuff is offline   Reply With Quote
