Old 08-06-2015, 08:41 AM   #9
19Fordy
19Fordy's Avatar
Default Re: intro and lowering my 4` coupe
Originally Posted by 1980gold View Post
19 fordy probably gonna start w removing some leaves. if I do every other spring do I have to change the steering arms. also how much will it drop. It rides like a mack right now.
I have never removed spring leafs so I can't provide an answer to that question. I would start by reversing the main spring leaf. It may "settle" even lower than 1 inch after a while. If you do decide to use a dropped axle be very sure than your tires will have adequate fender clearance when turning.Before you install a dropped axle speak with a company that actually drops axles and ask tons of questions. The folks on HAMB speak highly of Sid. Look here:
http://royboyproductions.com/2013/11...dropped-axles/
