Old 08-01-2015, 09:00 PM   #1
fresnoron
Default hard steering
have a 30 Tudor. All new steering balls, Teflon easy steer buttons, shorter pitman arm, all new king pins and bushings, new tires. Steers easy with front wheels off the ground but really hard with tires sitting on ground. Checked the king pin thrust bearing is taking the weight of the car so am assuming that's not the problem. maybe have the tir rod and drag link adjusted too tight, not sure...any ideas what I can do...do they make a steering box upgrade or upgrade kit? scratching my head on this one. Thanks Ron
fresnoron is offline   Reply With Quote
Old 08-01-2015, 09:46 PM   #2
Al 29Tudor
Al 29Tudor's Avatar
Default Re: hard steering
Are you trying to steer while standing still? You have to be moving at least slowly.
Al 29Tudor is offline   Reply With Quote
Old 08-01-2015, 09:56 PM   #3
pat in Santa Cruz
pat in Santa Cruz's Avatar
is the steering box full of grease or gear oil? grease will make it hard.
Should be 600w, but since thats not really available and anyway they leak a lot, Pennrite steering lube is preferred.
pat in Santa Cruz is offline   Reply With Quote
Old 08-01-2015, 11:22 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
What he said!
Old 08-01-2015, 11:29 PM   #5
Fred K-OR
Fred K-OR's Avatar
This is a model A Ford. Not known for easy steering.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 08-01-2015, 11:53 PM   #6
Brentwood Bob
f100 replacement?
Have you driven other model a's to experience how they steer, or not?
Bob
Brentwood Bob is offline   Reply With Quote
Old 08-02-2015, 12:27 AM   #7
SeaSlugs
SeaSlugs's Avatar
tires properly inflated?
my guess is your trying to turn it while stationary. any manual steering car does not want to turn its wheels easy while stationary.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 08-02-2015, 12:50 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Ron,
If you catch anything other than a BASS, do you throw them back??
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-02-2015, 12:57 PM   #9
Mitch//pa
go over Dads house he lives around the corner from ya. he'll show ya how to steer it
Old 08-02-2015, 02:22 PM   #10
fresnoron
I haven't kept a live fish in probably 20 years. Some trout, lotta strippers, and so many large and small mouth can't count them all. Fish every weekend on the Calif Delta. Good days there can be 40 or 45 fish per day. life is good
Old 08-02-2015, 03:45 PM   #11
H. L. Chauvin
We all got used to power steering and tend to forget what Model A's were like.
Just in case steering joints were not lubricated, some still recommend "not" greasing Model A Teflon joints; however, even with slight applied pressure and friction, lubrication usually always reduces friction between like or non-alike surfaces.
H. L. Chauvin is offline   Reply With Quote
Old 08-02-2015, 06:40 PM   #12
BILL WILLIAMSON
H.L,
Would greasin' yo' RASPY TONGUE reduce FRICTION between PERSONALITIES???
Bill W.
Old 08-03-2015, 12:13 AM   #13
Mike V. Florida
Not true unless you are standing still.
Old 08-03-2015, 11:31 AM   #14
Fred K-OR
Fred K-OR's Avatar
"To each his own"
Fred Kroon
1929 Std Coupe
1929 Huckster
Old 08-03-2015, 12:13 PM   #15
mshmodela
mshmodela's Avatar
Model A's steer about the same as an 8N... well almost
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 08-03-2015, 12:45 PM   #16
Bruce
Bruce's Avatar
Whoa ! Not so simple. Some stock Model A's steer MUCH easier than others. I know because I have one that is hiding a whole lot of friction and consequently turns a lot harder than the others. It doesn't like to center after a turn, either. I'm still searching for my prob.
In the case of this string, I'd check the shimming of the spindle bolt bearings first. The weight of the car might make a bearing jam even though everything turns easy when the wheels are hanging in the air.
Bruce is offline   Reply With Quote
Old 08-03-2015, 01:00 PM   #17
H. L. Chauvin
"Age" also makes a "big" difference ...... hmmmmmm?
Let us sometimes practice humility ........ not talking about the car either !!!!!!!!
Old 08-03-2015, 03:42 PM   #18
Larry Jenkins
Spindle bolt washers and/or tight King pins..
Larry
Larry Jenkins is offline   Reply With Quote
Old 08-03-2015, 08:12 PM   #19
Pete
One simple mod to a model A front end will make it steer easier
but I can't tell you what it is for liability reasons.
Any student of mechanical engineering can figure it out quickly.
