Old 07-14-2015, 09:03 PM   #41
mercman from oz
mercman from oz's Avatar
Default Re: Picked up a nice little 1953 Ford Sunliner over the weekend!
Here are some closeup shots of these 3 similar year Fords. The Maroon car is a 1952 model, the Blue car is the 53 model, the same as the Convertible in this Post. The bottom photo show all 3 years, starting off with the 54 model. While they are similar, the front fenders of each are all different and not interchangeable, though they will fit.
Old 07-15-2015, 07:06 AM   #42
itsa52
itsa52's Avatar
Nice car and a great price,, Top OK? Not sure about the K wheel I may have one.
itsa52 is offline   Reply With Quote
Old 07-15-2015, 07:39 AM   #43
wbedwards
wbedwards's Avatar
I like it! What a nice old ride!
wbedwards is offline   Reply With Quote
Old 07-15-2015, 09:40 AM   #44
Chris
Chris's Avatar
No, the top is bad. I may try replacing it myself. If you have a spare assessory wheel let me know!
Thee Inland Emperors
Chris is offline   Reply With Quote
Old 07-15-2015, 12:07 PM   #45
Sid the Maineiac
Sid the Maineiac's Avatar
Great car and great deal I would think ! Drive it like you stole it as I think you did !! lol
Sid the Maineiac is offline   Reply With Quote
Old 07-15-2015, 12:26 PM   #46
JSeery
JSeery's Avatar
The funnel should be good for short trips, very short!
Old 07-15-2015, 12:43 PM   #47
hotrodA
hotrodA's Avatar
Chris scores AGAIN!
It never ceases to amaze me what you drag home!
hotrodA is offline   Reply With Quote
Old 07-15-2015, 05:14 PM   #48
mercman from oz
For some unknown reason, the pictures on my Post above have disappeared, leaving little squares? I had close up shots of 1952 and 1953 Fords, plus a picture of a 1954, to highlight the differences. If you wish to look at these pictures, please go to my Test Forum. I will add the picture of the 1953 Ford again, and hope that it doesn't disappear this time around. This is the Grille that this lovely Sunliner should have.
Old 07-15-2015, 06:34 PM   #49
itsa52
itsa52's Avatar
I know where there is a 52/53 Merc accessory wheel,, complete but needs restored 250 but I'll bet he would sell for less
Old 07-15-2015, 09:08 PM   #50
itsa52
itsa52's Avatar
And now I know why they call it the "K" wheel
Old 07-16-2015, 02:08 PM   #51
flathead_jr
53s came with EAB flatheads not 8BA but it's possible someone found a good running swap. I know where there's a 53 rag top for sale in my area but it's a project for sure. I have a 54 I'd like to sell as well again a project! Both cars located in Southeast Idaho.
flathead_jr is offline   Reply With Quote
Old 07-16-2015, 02:41 PM   #52
Chris
Chris's Avatar
I called it an 8BA as thats normally what I refer to late model flathead engines as. After looking closely this car has Mercury heads. Makes me wonder if its a 239 or 255...
Old 07-16-2015, 07:40 PM   #53
flathead_jr
If it has the EAC Mercury heads chances are it's a Mercury engine, if so install a set of EAB heads and you'll have a way better set up anyways. The Ford had higher compression. With a 4" stroke you get 8:1 compression with Ford heads.
Old 07-24-2015, 02:53 PM   #54
Chris
Chris's Avatar
They do say EAC on the heads, but you can simply put Mercury heads on a Ford engine, correct? So it will be a guessing game unless I measured the stroke or pulled the pan
Old 08-24-2015, 12:26 PM   #55
Chris
Chris's Avatar
I got the brakes gone through, tank cleaned out and new fuel line run. I have rebuilt the carb, fuel pump and gone through the cooling system. Also painted some wheels and put new tires on it. It now drives but I still need to fiddle with the wiring and I need to look into why one rear brake locks when the brakes are applied.
I picked up a set of skirts to help hide the wonky repaired wheel wells. I also picked up a 53 vicky that has a lot of new and NOS parts as well as some nicer trim and such. I'm going to take what I need and sell the rest.
Old 08-24-2015, 12:58 PM   #56
Tim Ayers
Man, you just seem to have a knack for kicking up these old Fords. Rock on!
Old 08-24-2015, 03:37 PM   #57
1937pickup
Congrats-great looking car at a great price.
1937pickup is offline   Reply With Quote
Old 08-24-2015, 07:42 PM   #58
FL&WVMIKE
FL&WVMIKE's Avatar
You are lucky that the upholstery is usable. The converts had a hard time with that. You are, also, lucky, to make it original, you only need a grille and wheel covers. Maybe an air cleaner too.
In the 60s, I had a '53 hardtop, which I drove, daily, to work. The black paint, on the dash, looked so deep, it was, as if, you could stick your finger into it.
I had a chance to double my money on it, so I sold it. What a dumb thing to do. I found it on the back row of a car lot for $450.00, drove it for two years and sold it for $900.00. Sure wish I still had it. The $900.00 is long gone, now ! I had collected a large box of NOS parts, which I let go with it, including a NOS Coronado (fake Contininal kit) for it. 1950s parts were very inexpensive, in the 60s. The Ford dealers were junking them.
Have fun !
MIKE (mikeburch)
FL&WVMIKE is offline   Reply With Quote
Old 08-24-2015, 10:32 PM   #59
mercman from oz
The builder of this imported 1954 Ford Sunliner couldn't locate decent Parking Lights. Also, the original Grille needed to be chrome plated. His solution to this problem was to make a tube Grille, and thus saved lots of money in Chrome Plating. The finished car was painted in period style scallops.
Old 08-25-2015, 09:26 AM   #60
TJ
TJ's Avatar
You might want to buy the V-8 Club's 52-53 Ford book. It's a two volume set with a ton of information on these cars. These Fords are still affordable for young people on a budget that desire to get into the hobby. My first car was a '52 Merc in 1960. It was "nosed" and "decked" with lake pipes and Dodge Lancer caps. It had a flathead with a Merc-o-matic . Wish I had it back.
TJ is online now   Reply With Quote
