Old 06-29-2015, 10:59 AM   #2
MikeK
MikeK's Avatar
Default Re: Checking Head Surface for Flat?
Most guys will tell you a block deck (or head) can be checked for flatness with a machinist's straight edge or parallel. Unfortunately, this is WRONG!
This distorted plane will measure perfectly "flat" with a machinist's straightedge along any point perpendicular to any edge AND across opposite corners. It is extremely deceiving and can only be detected with a surface plate or more advanced electronic measuring that 'feels' or scans the entire surface.
Unfortunately it is also possible to produce this error while machining a block or head to correct an out-of -flat condition! It is very easy to instill a torque on a part when clamped for machining. The result is a distorted planar surface like the one above that may NOT be detectable with just a straightedge!
FWIW, most head gaskets will accommodate very slight distortions, up to 3 or 4 thousanths.
MikeK is offline   Reply With Quote
