Old 06-19-2015, 06:42 AM   #11
JWL
Default Re: Relieving 8BA Block
The false impression that relieving is good for competition engines because they operate at higher RPM will probably never die. Why? Because visual observations of Flathead flow paths seem to indicate a relief would be an improvement. Only after following the science with back-to-back flow bench and dyno tests can the facts be revealed.
The concept of using "seat-of-the-pants" as a point of reference or to collet data does not bode well for uncovering the facts. The fastest and quickest racing runs I have ever made actually felt the SLOWEST. I think this is because things happen very smoothly during the better runs. Those "hairy" runs with jolting wheel stands and power-drift crabbing at the top end are very impressive, but slow. Often there are those who make reference to speed records as proof of the value of relieving. But, since there are equally, or even more, magnificent records established with non-relieved Flatheads and since there is no way to determine how fast the sited record setter could have gone with no block relief, this is hardly a method which will determine validity.
I have no data on systems operating with air pressure beyond atmospheric.
JWL is offline   Reply With Quote
