Old 06-15-2015, 10:44 PM   #17
Ross F-1
Ross F-1's Avatar
Default Re: Bad fuel pump? 51 Custom
Then maybe you want to blow back into the tank from the filter bowl. You may have stirred up a bunch of loose rust.
Fast idle really doesn't burn near as much gas as going down the road. The line may be partially open.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
