Old 06-09-2015, 06:41 AM   #21
48 coupe
48 coupe's Avatar
Default Re: Engine turns backward???
I think your buddy had it in reverse and was bull sh///g u . or didn't know what he was doing. May be Bud was drivin,
48 coupe is offline   Reply With Quote
Old 06-09-2015, 07:15 AM   #22
LOWRIDER
LOWRIDER's Avatar
I recall my Dad mentioning flipping the center section in the rear end and getting the 3 reverse gears & 1 forward. Something to look at.
Dan Kingman Az. 86409
LOWRIDER is offline   Reply With Quote
Old 06-09-2015, 07:31 AM   #23
35slantback
Sorry for the negative comment Ronnie. I thought you were making a joke about my problem.
I will look at again as the last time we got it started was about 2 years ago, it ran for only a short time and we had 2nd gear in forward. I don't remember if we had 1st or 3rd in forward too. Then again it could have been in reverse and not in second, and we just didn't realize it,
We were outside in the daylight so the strobe effect was not an issue.
35slantback is offline   Reply With Quote
Old 06-09-2015, 07:34 AM   #24
35slantback
Again, thanks everyone for the help. I am new to the old Fords and this one had been messed with pretty badly before I got into it.
Old 06-09-2015, 07:48 AM   #25
Marv
Marv's Avatar
I can not understand how a flat head Ford starter can turn an engine backwards. Look how the starter bendix is made. The engine could kick backwards.
Marv is offline   Reply With Quote
Old 06-09-2015, 07:52 AM   #26
Marv
Marv's Avatar
Talking Re: Engine turns backward???
By the way, was this after a long day and was alcohol involved? LOL
Old 06-09-2015, 07:59 AM   #27
Mike51Merc
Mike51Merc's Avatar
Just to be sure I'm understanding the issue: The engine turns backwards when push starting it, but only when the ignition switch is turned off?
I've read some weird stories on internet forums, but this one is in the top ten.
Sir, that's simply impossible.
Mike51Merc is offline   Reply With Quote
Old 06-09-2015, 09:57 AM   #28
Ronnie
Ronnie's Avatar
X 4 on that statement. Can't happen.
R
Ronnie is offline   Reply With Quote
Old 06-09-2015, 10:00 AM   #29
George/Maine
George/Maine's Avatar
I don't think you could have the reared upside down not on a orginal car. The drain hole would be up top.
I have a 6 volt car and someone before changed the neg ground and starter works good. Just get it started with a good battery.
George/Maine is offline   Reply With Quote
Old 06-09-2015, 10:25 AM   #30
Ronnie
Ronnie's Avatar
Stranger things have been done.
R
Old 06-09-2015, 10:28 AM   #31
40 Deluxe
George/Maine, The whole rear end is not turned upside down; rather the ring gear is installed from the wrong side. Since the center section and housings are symmetrical, everything goes together just fine, but the axle shafts now turn the opposite direction.
Old 06-09-2015, 10:30 AM   #32
scicala
scicala's Avatar
Call Rod Serling for advice.
Sal
scicala is offline   Reply With Quote
Old 06-09-2015, 11:27 AM   #33
35slantback
Marv,
No alcohol but we sure thought about it.
The starter worked fine and turned the engine in the correct rotation...was just when we were trying to roll-start it that it changed direction with the switch on.
I'm going to go through it again just to make sure without doubt it wasn't in reverse instead of 2nd.
Old 06-09-2015, 11:31 AM   #34
Mart
Mart's Avatar
If you put it in top (3rd) you can be sure you are not accidentally in reverse and check what happens and rule out any upside down diff possibility (however slight) You only need to move it a few inches forward to see the engine kick clockwise from the front.
Mart.
Mart is online now   Reply With Quote
Old 06-09-2015, 11:53 AM   #35
Ronnie
Ronnie's Avatar
Originally Posted by 35slantback View Post
Marv,
Having the switch on or off has no influence on engine rotation when pushing or towing to try and start.. We can only comment on what you are stating in your post.
R
Old 06-09-2015, 12:07 PM   #36
GB SISSON
GB SISSON's Avatar
I had an old 6 cyl landcruiser and I was dribbling atf down the throat of the carb trying to decarbonize it from what could be an old wives tale, but this isn't... After a couple minutes and some hiccups and near stalls, it hiccupped and started running backwards. It started racing up really fast so I went into the cab and switched off the ignition. No change, just mad acceleration. I can only think it was running as a diesel, fueling itself off hot atf sucked in from the oily wet exhaust and probably a pool in the muffler. There was a geyser of black crud exhausting out of the carb and the tailpipe was now the intake. Should have stuck a potato in the exhaust to kill it, but was just too freaked out watching this happen. Before this I had no Idea a normal 4 cycle gas engine can run so well in reverse. I would have thought the cam would have needed to be ground differently like a twin engine boat. But they can run backwards. No I didn't get a video.
Old 06-09-2015, 12:08 PM   #37
V8COOPMAN
V8COOPMAN's Avatar
Articulate, concise communication might clear-up the problem, or the question. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-09-2015, 12:12 PM   #38
George/Maine
Sounds like auto class .If some one has a rear and see if it can be upside down.
After Ford had few wrong ones they would have drill hole to go one way.
Old 06-09-2015, 12:14 PM   #39
V8COOPMAN
V8COOPMAN's Avatar
Ahhhhhh.........like I said! DD
T5 W/TORQUE TUBE
Old 06-09-2015, 12:32 PM   #40
zzlegend
zzlegend's Avatar
Well since there was no alcohol involved, ,,,,,,,,how about "wacky tobacky"? That stuff can play tricks on the cranial cavity.
zzlegend is offline   Reply With Quote
