Lets see now.
#1 Crank shafts don't bend in storage -- No matter if stored standing up or laying down. #2 Engines hung on engine stands by the bell housing will never break and fall to the ground. # 3 There is no such thing as Vapor lock. #4 ( can you add any that I may have missed )
#4 Ethanol is fine for old cars and lawn equipment
#5 Back in the day my flathead never overheated
#6 Those lever shock arms come right off with a little heat and a hammer
Why was it that my uncle had a '39 Ford in the late 40's that was overheating??
BOY THATS GOING TO LEAVE A MARK |
Scott read post #4 Charlie NY Back in the day my flathead " NEVER" over heated !!!
MMO is the nector of Gods - will cure everything including vapor lock
Thanks - 30-9 1939, 1940 |
Don't you dare put those fined heads on that flathead. There only original once.
#? "No problem aligning that front sheet metal on '40 Fords"
"Get your facts first..then you can distort them as you please" |
# 10 Heck it won't take NO time or MUCH $$$ to finish this fresh basket case barn find >>>>>>>>>>
#13 |
# 11 Honey if you let me buy this car I PROMISE I will sell one of the other ones !!!
#14 |
Any tool / nut or bolt dropped while working on a vehicle will be found exactly in the center of said vehicle
This being true if part/tool makes it to the ground. Nothing worse than dropping part/tool and having it not make it to the ground...... Can I get a AMEN brother???? |
#15 |
Should start right up , it has only been 30 years.
O , yes and the moon is made of cheese.
[FONT=Comic Sans MS] |
#16 |
Bill, you have been eavesdropping.
You are never to old to enjoy your childhood. Forty1fordpickup on the HAMB. |
#17 |
Don't forget, lifting an engine by a carburetor base plate on an aluminum intake is fine and will never come loose.
Matt 24:36-41 |
#18 |
Don't worry, it'll polish out
#19 |
You said there is NO rust on it........well you got to really look to ever see that
You said that the paint is real nice.......well you got to really look to ever see that Youy said the body is near mint.......well you got to really look to ever see that .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN What I GOT DONE TODAY... I got the rear-end put in the recliner, and now I'm going to rest up & watch TV.
#20 |
