Old 12-22-2014, 04:06 PM   #1
Richie R
Default Model A Torqueflite 904 kit
I have just picked up a Torqueflite 904 kit from Bert's Model A.
Is is just a basic kit where it's just the adaptor for the crank and bell.
Has anyone fitted one have any advise on the crank bolts, did you have the crank drilled with extra holes.
It's most likely the only 904 kit in this country, anyone have any advise on fitting it?
Before anyone asks, yes I have asked on the HAMB.
Richie R is offline   Reply With Quote
Old 12-22-2014, 04:15 PM   #2
Mitch//pa
Default Re: Model A Torqueflite 904 kit
all that i can add is that the torqueflight utilizes a linkage or cable connected to the throttle linkage on the motor to operate the throttle valve for upshifts, unlike a c-4 or say a t-350 which uses a vacuum modulator...
Old 12-22-2014, 04:28 PM   #3
d.j. moordigian
d.j. moordigian's Avatar
I saw a 904 in a Model A at the Antique Nationals about 15 years ago.
That's all that I remember...
d.j. moordigian is offline   Reply With Quote
Old 12-22-2014, 04:52 PM   #4
SteveB31
SteveB31's Avatar
Contact Art Moore at [email protected]. He has it in both of his cars. And it is vacuem controlled. Works great!!!!
Steve BEcker
Berts Model A Center
SteveB31 is offline   Reply With Quote
Old 12-23-2014, 04:34 AM   #5
Richie R
Steve BEcker
Thanks Steve
Thanks for the kit and quite a reasonable price for part and shipment too. Just need to work out how to get the adaptor to fit the engine, and the rest of the fitment into my A is more in my knowledge field.
Old 12-23-2014, 05:05 AM   #6
colin1928
colin1928's Avatar
Rich taping the crank for the extra 2 bolts is no big deal I do it on my modified engines and use arp bolts much stronger and maybe thought necessary by the kit manufacturers
colin1928 is offline   Reply With Quote
Old 12-23-2014, 07:43 AM   #7
Mitch//pa
Steve BEcker
TV pressure controlled by vacuum,,don't think so??
Old 12-23-2014, 11:02 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I don't recall hearing that term for bolts. What are "arp bolts"? Thanks
Old 12-23-2014, 11:13 AM   #9
CarlG
CarlG's Avatar
ARP | The Official Web Site
arp-bolts.com/
Automotive Racing Products
Manufacturer of fasteners found in engines and drivelines, ranging from OEM replacement parts to specialty hardware for racing applications.
I have their head studs on my engine. Great products.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-23-2014, 11:15 AM   #10
Jim Brierley
ARP manufactures high quality bolts, most racers use them. American Racing Products
Old 12-23-2014, 11:17 AM   #11
Jim Brierley
art moore has found that a heavy-duty flex-plate is necessary, but he races his.
Old 12-23-2014, 12:12 PM   #12
Vic in E-TN
Carl:
Do you have the product number easily available for the ARP head studs for the A engine?
Vic
Vic in E-TN is offline   Reply With Quote
Old 12-23-2014, 12:26 PM   #13
CarlG
CarlG's Avatar
Originally Posted by Vic in E-TN View Post
Carl:
Vic
12 ea AP3.500-ISB
2 ea AP5.750-ISB
Depending on your head, these may be a quarter inch too long. If they are, just order shorter ones or use a really thick SAE washer under the nut. The length is in the part #.
No need to tell them you are buying these for a Model A, they've never heard of one.
Alaskan A's
Old 12-24-2014, 11:06 AM   #14
Bob Bidonde
Bob Bidonde's Avatar
When using high strength bolts that engage threads in a Model "A" engine block, keep in mind that the weak link is the threads in the gray iron block. Thus the high strength bolts and or studs are of no value.
Bob Bidonde
Old 12-24-2014, 11:29 AM   #15
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Kinda odd don't you think that these very fasteners are made to use in high-performance applications which also use cast iron and aluminum blocks. Do you suppose they are no value in those engine blocks either?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-24-2014, 12:11 PM   #16
CarlG
CarlG's Avatar
Originally Posted by forever4 View Post
Carl,
I think you better recheck that second part number.
I can re-check my invoice from them as well as measure what I have on my engine.
The sizes I listed are 1/32" longer than what is in Snyder's catalog:
Regular short studs: 3-15/32". Long outlet studs: 5-23/32".
Alaskan A's
Old 12-24-2014, 07:42 PM   #17
Richie R
The flex plate with this kit is about 4mm thick, looks a lot stronger than any OEM flex I have ever come across.
I guess with the big 4s harmonics it needs to be.
Old 05-30-2015, 07:56 AM   #18
C26Pinelake
Here is your December post ???
Wayne
C26Pinelake is offline   Reply With Quote
Old 05-30-2015, 11:32 AM   #19
Barber31
Barber31's Avatar
Brent, Don't take this as sarcastic. Genuinely curious, could it be possibly that the properties that make up cast iron in racing blocks are far superior than our model A blocks? I remember reading changing the percents of what's added to iron/aluminum can effect its strength and wearability.
Barber31 is offline   Reply With Quote
Old 05-30-2015, 11:37 AM   #20
just plain bill
just plain bill's Avatar
Snyders sell a set of head studs made from the same material as ARP at a more reasonable price.
just plain bill is offline   Reply With Quote
