Old 05-27-2015, 08:06 PM   #1
Willynch
Default Spark lever question
To start, I retard the spark with the lever all the way up. Once the car starts, I advance the spark with the lever all the way down. Even when warmed up, if I try and move the spark lever up from the "all the way down position" the engines slows and stalls. In otherwords, it seems I can only run with spark advanced all the way.
I am rebuilding the carb because of leaks. Once that is completed, how do I improve the performance of the spark adjustments?
Thanks
Willynch is offline   Reply With Quote
Old 05-27-2015, 08:14 PM   #2
My1930ModelA
Default Re: Spark lever question
I would first check to make sure the lever travel equals full travel of the distributor plate from fully retarded to fully advanced. If your car is a 30 or 31, the steering shaft can be rotated to accurately set the travel. Then I would check for the overall condition of the distributor, looking for worn bushings causing shaft wobble. Clean or replace the points and set them accurately to .020" gap. Finally check and accurately set the spark timing using the dimple in the timing gear to find TDC on #1 cylinder and rotating the distributor cam per instructions for setting timing. Good luck and I think you'll find a real good idle!
My1930ModelA is offline   Reply With Quote
Old 05-27-2015, 08:14 PM   #3
Mitch//pa
make sure your spark rod throws fully in each direction at the distributor body opening.
then reset the timing to specs.
it sounds like your timing is to far retarded
Old 05-27-2015, 08:20 PM   #4
pat in Santa Cruz
pat in Santa Cruz's Avatar
I would also check the wire between the two plates. Its not uncommon for it to short against the spring or the side of the distributor when the lever is in certain positions that cause it to make contact.
pat in Santa Cruz is offline   Reply With Quote
Old 05-28-2015, 07:33 AM   #5
Mike V. Florida
Mike V. Florida's Avatar
The owners manual tell the owner where to place the lever.
Not having one, you can start all the way up, when driving at any given speed slowly lower the lever taking note of the engine speed. As the lever is lowered the speed on the engine will increase. At the point the engine stops increasing, that is the optimum for the timing.
So with that said if you cannot start and idle the car with the lever up, you have a timing problem.
I would go back, and following the suggestions above, re time the engine. Be sure the lever is all the way up when you do so. If the timing is correct and the point just open with lever just off the top, you need to look else where for the problem.
Old 05-28-2015, 09:02 AM   #6
30ccpickup
30ccpickup's Avatar
Drawing of what My1930ModelA and Mitch//pa are suggesting.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 05-28-2015, 11:04 AM   #7
Steve Wastler
Steve Wastler's Avatar
My first thought was like Pat suggested, check that wire....
Steve Wastler is offline   Reply With Quote
Old 05-28-2015, 11:39 AM   #8
willobs
In the second pic is the cam moving sideways or am I looking wrong!
willobs is offline   Reply With Quote
Old 05-28-2015, 11:55 AM   #9
31Tudor
31Tudor's Avatar
That second picture is a little deceiving. The plate moves around the cam, not the cam moving back and forth.
31Tudor is offline   Reply With Quote
Old 05-28-2015, 11:59 AM   #10
31Tudor
31Tudor's Avatar
Watch the location of the points wire and nut holding the points to the plate as the plate is moved through its travel. Be sure the nut, wire end is not touching the side of the distributor or the spring inside when it is moved. This can also be checked with an OHM meter.
Old 05-28-2015, 12:03 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Nothing is moving...........what have you been drinking?
Actually he's showing what happens when the bushings are worn out.
Old 05-28-2015, 12:04 PM   #12
Bob C
If you go to the link it is showing what bad bushings look like.
Bob
Old 05-28-2015, 12:08 PM   #13
30ccpickup
30ccpickup's Avatar
I apologize for not being clear. The second photo is showing the back and fourth wobble that is a sign of bad busshings, which My1930ModelA pointed out.
Old 05-28-2015, 12:09 PM   #14
30ccpickup
30ccpickup's Avatar
Everyone types faster then me!!
Old 05-28-2015, 12:23 PM   #15
Mitch//pa
love your animated tech things... thanks for taking the time to post them
Old 05-28-2015, 12:48 PM   #16
marc hildebrant
marc hildebrant's Avatar
Thanks
After you check your timing, you should adjust the timing lever for the road condition you have. It is used for adjustment, not for min or max.
Refer to the Model A owners manual for a good description.
Marc
marc hildebrant is offline   Reply With Quote
Old 05-28-2015, 03:31 PM   #17
Willynch
Thanks. Once carburetor is back in the care, I will adjust timing.
Old 05-28-2015, 05:46 PM   #18
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
It's pretty apparent that the timing's TOO SLOW. When you got one like this, just loosen the dist cam screw, turn the cam a bit CCW, tighten the screw & see if it sounds better. At least, you'll know if you're on the right track. Once you KNOW the sounds & reactions of a Model A, you CAN set the timing, WITHOUT even removing the timing pin & going through all that "MONKEY MOTION"---The Dog's LAFFIN'--What's a man to do????
Bill W.
"THE ASSISTANT GURU OF STUFF"
