Old 05-18-2015, 09:48 AM   #1
ford31
ford31's Avatar
Default motor/gas tank additives
what(if any) is a good additive to keep things working for model a's not driven much
ford31 is offline   Reply With Quote
Old 05-18-2015, 10:13 AM   #2
eagle
eagle's Avatar
Default Re: motor/gas tank additives
A little Marvel Mystery oil in the tank at fillup if its going to sit much. Definitely use premium no-alcohol gas if it is available in your area, it is here and I won't run anything else.
Old 05-18-2015, 11:21 AM   #3
ford31
ford31's Avatar
must be something to mystery oil,my dad whos gone now,was never without his mystery oil,his car and anything that had a motor got mystery oil,and seemed to run forever,guess I forgot that,thanks for reminder
Old 05-18-2015, 01:18 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
X 2, plus clean oil in the engine when it's stored.
My cars set for 6 to 7 months over road salt season, otherwise they get driven now and then during the summer. I don't drive just to be driving, but I would like to do some travelling to visit places I've never seen. I've never been to the west coast, and never driven along the east coast. I'd also like to do what's left of Route 66 before it's all gone.
Old 05-18-2015, 07:34 PM   #5
glenn in camino
glenn in camino's Avatar
Snake oil.
Old 05-18-2015, 08:10 PM   #6
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
Toms right about clean oil when storing. Along with that is when ever its started, and not going to be restarted soon, warm the engine up to temp plus some time. That helps evaporate moisture in the oil, ect that comes from combustion.
Old 05-18-2015, 11:09 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
MM, Sea Foam are about the only things that could do some good that could be added to fuel.
Old 05-19-2015, 09:33 AM   #8
JD 1931
JD 1931's Avatar
Marvel mystery oil at fill ups....
JD 1931 is offline   Reply With Quote
Old 05-19-2015, 12:29 PM   #9
30aadoodlebug
30aadoodlebug's Avatar
I run Marvel Mystery Oil and a splash of generic lead substitute. All three of my A's seem to be happy thus far.
30aadoodlebug is offline   Reply With Quote
Old 05-19-2015, 03:17 PM   #10
Mad Mac
What about Morey's upper cylinder lubricant? Not sure if MMO is available here in New Zealand
Mad Mac is offline   Reply With Quote
Old 05-19-2015, 03:26 PM   #11
Nabco
Nabco's Avatar
I was told not to add lead substitute because lead was not added to gas until the early 50's....does more harm then good
Nick
Nabco is offline   Reply With Quote
Old 05-19-2015, 06:13 PM   #12
Tom Wesenberg
Actually gas had lead by the late 20's, but Model A's and most of our older cars do fine without it. The plugs last much longer and the oil stays cleaner.
Old 05-19-2015, 09:02 PM   #13
dlfrisch
dlfrisch's Avatar
From past experiences - I use Marvel Mystery Oil to all of my mechanical machinery. I add 3 or 4 oz. to my full tank of gas in my "A", add a bit to my pressure washer, generator, lawn mower, etc. and if I remember....we (my wife and I) add a couple of ounces to our Harley Davidsons. It seems to keep fuel machinery from deteriorating and helps to keep fuel from varnishing-up from long storage times.
dlfrisch is offline   Reply With Quote
Old 05-19-2015, 09:20 PM   #14
Skibb
Skibb's Avatar
Ditto
Skibb is offline   Reply With Quote
Old 05-19-2015, 11:20 PM   #15
norcalal
MM oil is fine from all I have spoken with, However I always use ATF (Any kind) and it has always worked wonders as as fuel stabilizer, and wont vapor lock on hot days. Cheap and works. Does it get any better than that?
norcalal is offline   Reply With Quote
Old 05-20-2015, 02:17 AM   #16
30aadoodlebug
It should be available. If not, send me your address and I'll send you a case from the states. Wouldn't run an 'A' without it.
Old 05-20-2015, 06:29 AM   #17
updraught
updraught's Avatar
It says roughly: In 1927 approx. 14%of cars were high compression (5 to 1 or higher). By 1928 it was 56%. 1929 77%. Don't think Henry believed in lead.
updraught is offline   Reply With Quote
Old 05-20-2015, 10:41 AM   #18
fredski
fredski's Avatar
Originally Posted by glenn in camino View Post
Snake oil.
I never tried snake oil or ever seen it for sale, but I am sold on
Sea foam.
Fredski
fredski is offline   Reply With Quote
Old 05-20-2015, 10:59 AM   #19
BlueSunoco
Originally Posted by updraught View Post
Attachment 224786
Believe you are on to something as I read once where Tetra Ethyl Lead additive was developed at GM laboratories, and Mr. Ford hated paying royalties or supporting any of his competition in any way financially.
One reason Ford Benzol was developed plus it was a Ford by-product? Benzol was only available in the Detroit area. A Ford Benzol gasoline globe is a rare and very desirable collectible.
BlueSunoco is offline   Reply With Quote
Old 05-20-2015, 11:53 AM   #20
raprice22
I routinely all Sta-bil to my gas tank after every fill up. I don't trust modern gasoline to remain stable while the car sits in the garage.
Rog
raprice22 is offline   Reply With Quote
