#17 |
I've driven mine on some fairly steep grades, and like many have said hills are no problem, speed and traffic are the issues because you cant pull a steeper grade in 3rd without lugging it, and 2nd is pretty low so your RPMs are screaming if you want to keep up - this is where an overdrive really shines being able to split the gap between 2nd and 3rd. I almost equate this as much as an asset as being able to go a few mph's faster in 3rd on more level ground.
Aaron in T̶a̶c̶o̶m̶a̶ Meridian, Idaho (although still a Montana hillbilly at heart )1931 Coupe 1931 slant window sedan Last edited by montanafordman; 04-15-2015 at 01:31 AM. |
