04-09-2015, 06:22 AM | #61 |
Re: Oil pan 59AB photos
Thank you so much for the photos JSeery, have the same lines and holes, that I have been drawing.
If is possible yet, can you take a close-up of the areas that I marked? Thank you very much. All the best, Jorge |
04-09-2015, 07:44 AM | #62 |
See if this is what you are looking for. PM me your email address and I will email back the original higher res photos (around 4Mb)
04-09-2015, 11:03 AM | #63 |
Thank you JSeery.
04-13-2015, 11:43 AM | #64 |
In progress
04-14-2015, 02:13 PM | #65 |
04-14-2015, 06:43 PM | #66 |
04-14-2015, 06:53 PM | #67 |
What are the components that are not correct?
04-14-2015, 10:25 PM | #68 |
04-14-2015, 10:31 PM | #69 |
59a and 8ba cams rotate in opposite directions, so the teeth on the gears would be in the opposite direction. The crank gear and the cam gear are matched sets.
04-14-2015, 10:37 PM | #70 |
04-15-2015, 05:44 AM | #71 |
So it is only the diretion of the teeth gears correct, I need flip over the both gears teeth?
Thank you so much by the notice. JOrge |
04-15-2015, 08:31 AM | #72 |
04-15-2015, 08:36 AM | #73 | |
http://www.vanpeltsales.com/FH_web/F...timinggear.jpg http://www.vanpeltsales.com/FH_web/F...ngear-alum.jpg http://www.vanpeltsales.com/FH_web/F...m_1940to48.JPG http://www.macsautoparts.com/ford_me...passenger.html http://www.honestcharley.com/hot-rod...-alum-59a.html R Last edited by Ronnie; 04-15-2015 at 10:28 AM. |
04-15-2015, 10:53 AM | #74 |
Thank you so much Ronnie by the notice and the photos too.
As I don't know of any existing engine near me not always it is clear, my support it is photos that I found in my searches or some help from the members of the forum. Now i believe that is correct, the left that i have, the right it is the new one. The engine that I have been designed it is the 59AB. Thank you all for the help All the best, Jorge |
04-15-2015, 01:50 PM | #75 |
Sorry about that, not totally awake on that one!!!!! The thrust of the cam is reversed, not the cam rotation. The 59a thrust the cam toward the engine and the 8ba thrust the cam toward to cover because of the cut of the gears. Some days are better than other!
04-15-2015, 01:51 PM | #76 |
11-15-2019, 05:17 PM | #77 |
Great work that model is really neat! Would you share a .step file of the 59AB intake manifold?
I would love to 3D print one for my desk! Jesse |
11-15-2019, 07:37 PM | #78 | |
The original poster was last active on this site in 2015
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
