Old 04-14-2015, 08:21 AM   #1
flatheadfan
flatheadfan's Avatar
Default Need a sure-fire method
Does anyone have a sure-fire method to prevent the locking pin (connects floor shift handle to trans cover top), from falling into the darken depths of the transmission when the handle is removed? This has happen a couple of times to me and it is no longer "fun" to retrieve it.
Thanks
Tom
flatheadfan is offline   Reply With Quote
Old 04-14-2015, 08:24 AM   #2
Mike51Merc
Mike51Merc's Avatar
Default Re: Need a sure-fire method
Hold a strong magnet on the edge of housing?
Mike51Merc is offline   Reply With Quote
Old 04-14-2015, 10:44 AM   #3
ford38v8
ford38v8's Avatar
Sure fire: Don't separate the shaft from the housing. Take off the complete assembly.
Alan
ford38v8 is online now   Reply With Quote
Old 04-14-2015, 12:03 PM   #4
donald1950
after you unscrew & remove the cap. use a small screwdriver down the slot in the shift lever to push it out into your hand
donald1950 is offline   Reply With Quote
Old 04-14-2015, 12:24 PM   #5
Charlie ny
Tom,
My preference is to open the 1/4"dia hole enough oversize to make it
reasonably round then turn up an oversize pin from oil hardening steel. I size the
new pin for a stiff tap fit. It's not a quick fix but it is a good repair and the big
benefit is the shift stick no longer wallows around in the tower.
Charlie ny
Old 04-14-2015, 02:39 PM   #6
flatheadfan
Donald-
Your suggestion seemed simple enough so I gave it a try. Using a micro screwdriver the pin came out just as you suggested! Often the simplest solutions are the best! Thanks for the help!
Tom
Old 04-14-2015, 02:46 PM   #7
flatheadfan
Charlie-
I liked your idea and it seems that it also would reduced gearshift slop but I am rather hesitant attempting it while the cover is still attached to the trans which is under the floor pan. This sounds like a good "bench idea" which I will probably will end up doing the next time I have things more apart. Thanks!
Tom
Old 04-14-2015, 03:18 PM   #8
Admiral
Admiral's Avatar
The problem is your shifter housing is far too clean. You need a thick coating of filth and rust to lock that pin in place .
Admiral is offline   Reply With Quote
Old 04-14-2015, 06:44 PM   #9
Thaplumbr
Thaplumbr's Avatar
Didn't ford have a part number for that as well?...lol
Thaplumbr is offline   Reply With Quote
Old 04-14-2015, 06:57 PM   #10
Talkwrench
Talkwrench's Avatar
How does it fall in the shifter goes in then the pin, from memory the pin has no way of getting down into the box.. How do you withdraw the shifter without removing it totally?
Old 04-15-2015, 04:14 PM   #11
1931 flamingo
1931 flamingo's Avatar
It's a slip fit and if not careful it's very easy for it to fall into the tranny, especially if you're a newbi and don't know it's there............
Paul in CT
Old 04-15-2015, 06:55 PM   #12
donald1950
Murphys Law: if it can fall, it will & it will take 2 hours with a magnetic wand to retrieve it......
Old 04-15-2015, 10:46 PM   #13
B-O-B
B-O-B's Avatar
Locktite!!!!!!!
B-O-B is offline   Reply With Quote
