#21 | |
#22 |
If it is a 32 original k member you will pull the motor
#23 |
JM 35 Sedan/John,
Looking like it's coming along nicely, keep up the good work, keep the photo's coming, it does make it easier on those thinking about tackling a job like this. The updates are priceless, the ability to see progress, parts and considerations as you replace the old parts. |
#24 |
Complete new clutch installed. It slips. What is correct number of pressure plate? What measurements can I take to insure I have the correct one? I had to extend the clutch adjusting rod to get correct free play. What does this tell you? If wooden blocks are still in the plate will they fall out when the clutch is released? If not, what is best way to remove them? When is the best time to remove them? I assume you leave them in at least until the pressure plate is attached to the engine. thanks
#25 |
For the life of me, I can't comprehend...."Be sure to relieve the tension on the pressure plate by placing wedges between the arms and the cover. This will prevent warping the cover and reduce the chance of chatter" Or "If wooden blocks are still in the plate will they fall out when the clutch is released? If not, what is best way to remove them?" My clutch is way chatter free. Can someone explain or have picture.
#26 |
One of those little red things that the tranny is hanging by sure makes the job so much easier. |
