Old 02-11-2015, 10:12 PM   #1
Shadetree
Shadetree's Avatar
Default Engine Test Stands~Lets See Them!
I have a 59 engine with 59AB heads that I traded for several years ago. It has about 14,000 miles since a factory overhaul according to the last owner which I trust. I would like to mount it on a mobile test stand so I can start it occasionally. I have all of the components to do this, even a `41 pickup transmission and a `35 radiator.
I am sure some of you have test stands. Please post pictures. Give me some ideas.
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 02-12-2015, 10:41 AM   #2
toby
toby's Avatar
Default Re: Engine Test Stands~Lets See Them!
Go to the search tab, advanced, then type in engine test stands, then choose early V8 in discussion forums. There are three threads with test stands and pics.
toby is offline   Reply With Quote
Old 02-12-2015, 02:47 PM   #3
Cecil/WV
Cecil/WV's Avatar
Here's mine with an 8BA with 8BA water pumps and the Mercury bell housing.
Cecil/WV is offline   Reply With Quote
Old 02-12-2015, 02:49 PM   #4
Cecil/WV
Cecil/WV's Avatar
Another shot
Old 02-12-2015, 02:55 PM   #5
Shadetree
Shadetree's Avatar
Cecil,
I like that. Thanks for posting.
Old 02-12-2015, 03:48 PM   #6
tubman
tubman's Avatar
I have a couple of different kinds of engines that I wanted to run, so I wanted to make a universal stand. To do this, I bought a cheap engine stand from Harbor Freight, and cannibalized the guts of it to make a universal rear mount. For the front, I did an "analog" of the old Hurst system. (Remember, you would get the specialized front mount for your engine and then buy the proper frame adapters?) The rear mount is mounted rigidly to the stand, while the front mounts can slide back and forth to accommodate different length engines. I have an early Hemi on it now and have an Olds Rocket, and a couple of 8BA's to go. If you're only doing one engine, you obviously don't need to go to the trouble. The adjustable rear mount does seems the the easiest way to go, though. I'm in Florida for the winter, so I can't post pictures, but I'm sure you get the general idea.
Old 02-12-2015, 09:11 PM   #7
Ol' Ron
Ol' Ron's Avatar
I'd show you mine,but, It's an old truck tire buried in the snow.
Old 02-12-2015, 10:08 PM   #8
Don
Don's Avatar
Sent you a few pic Bud..if you need more,just let me know,.
DON P
Don is offline   Reply With Quote
Old 02-12-2015, 10:12 PM   #9
Don
Don's Avatar
Forgot to mention Bud, get good rolling wheels with brakes,makes things easy to roll around. Think I found mine at the flea market,HF also has them,if you need the height ,let me know.
DON P
Old 02-13-2015, 04:09 PM   #10
Shadetree
Shadetree's Avatar
Good suggestion Don. I like the looks of the one you built.
Bud
Old 02-13-2015, 05:14 PM   #11
barnfind
The HF heavy duty engine stand can provide most of the materials you need to build one very inexpensively. I have 4 done 5 of those.
But I have also used a 15x7 steel wheel with a 205x70x15 blackwall inflated to ~25 PSI. Strap it to a movers dolly and it becomes portable.
barnfind is offline   Reply With Quote
Old 02-13-2015, 09:30 PM   #12
Sixseven
Sixseven's Avatar
I know your serious Ron, at least I think you are. Doesn't engine torque shift the engine around?
Sixseven is offline   Reply With Quote
Old 02-13-2015, 10:08 PM   #13
Ol' Ron
Ol' Ron's Avatar
Yep!! have a coupls cinder blocks for that. All I need is and oil pressure gauge.
Old 02-13-2015, 10:20 PM   #14
Don
Don's Avatar
Finally figures out how to post a picture,the radiator hangs from the front posts by welding some legs that stick out,couldn't find a finished pic
.If I leave the transmission on I use a sissor jack to hold up rear
DON P
