Old 07-30-2014, 11:01 AM   #121
Mart
Mart's Avatar
Default Re: Flathead project
Look like wide to me. You only get thin belts on later type (Post 59A) pumps.
Mart.
Old 07-31-2014, 04:49 AM   #122
LSJUNIPER
OK, Thanks Mart..
LSJUNIPER is offline   Reply With Quote
Old 07-31-2014, 04:53 AM   #123
LSJUNIPER
Thanks to BUBBAS IGNITION!!!!!!
Old 07-31-2014, 06:20 AM   #124
GreenMonster48
GreenMonster48's Avatar
Thats a sweet lookin' set up!
GreenMonster48 is offline   Reply With Quote
Old 07-31-2014, 10:30 AM   #125
LSJUNIPER
Thank you....
Old 07-31-2014, 11:15 AM   #126
TonyM
TonyM's Avatar
Looks great!!!
TonyM is offline   Reply With Quote
Old 07-31-2014, 11:18 AM   #127
done4
done4's Avatar
Send a message via Yahoo to done4
Just read your thread, don't know how I missed it. Seems like you lucked out from the get go and have there one fine flathead. What are you putting it in. I didn't see any info on that.
Still smokin tires and cigars
done4 is offline   Reply With Quote
Old 07-31-2014, 11:30 AM   #128
Bolts
Bolts's Avatar
LS,
Thanks for taking the time to share this project with us. Never having taken a flathead apart, I really appreciate seeing what you did with yours and reading all the accompanying posts.
Nothing wrong with it except for the name on the front.
Alex
Bolts is offline   Reply With Quote
Old 07-31-2014, 02:31 PM   #129
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
LSJUNIPER, very nice job. I love it. What are you using for a cam? Stock or performance? Where did you get the carbs? Do you know what the jets and power valves size are? I'm full of questions. Thanks Walt
Old 07-31-2014, 02:31 PM   #130
super flat
super flat's Avatar
LOOKS GREAT, and your pulleys are wide belt, as is proper for your flathead! Gary
I am usually relatively happy------Gary
super flat is offline   Reply With Quote
Old 07-31-2014, 03:03 PM   #131
sam03
wow just read through the thread. Great work! I hope the flathead i'm getting this weekend is a good one.
sam03 is offline   Reply With Quote
Old 07-31-2014, 03:15 PM   #132
sidevalve8ba
sidevalve8ba's Avatar
I really like this build. What are you planning to put this engine in when you finish?
sidevalve8ba is online now   Reply With Quote
Old 08-02-2014, 08:21 PM   #133
LSJUNIPER
Thanks for all the interest and compliments. The cam is an Isky, 77B, mild cam...the carbs are from Speedway Motors, its there Super 7 Carbs. I purchased there kit. It comes with the carbs and the intake. I am going to put the motor in a 29A frame I also purchased from Speedway. A friend of mine used to make frames for dragsters, he is going to weld it up for me on his frame table.I am not sure what I am going to put on the frame as far as a body. I really would like to put a modal A coupe body on the frame, but I am finding out that they are hard to come by. I have thought of putting a 1946 ford truck body on the frame...We will see when I get there....
Old 08-03-2014, 07:14 AM   #134
moonshine runner
moonshine runner's Avatar
Very nice work!! Thank you for posting your progress and showing us all this renewed Flatty!
Kevin
"Failure is simply the opportunity to begin again, this time more intelligently".
Henry Ford.
moonshine runner is offline   Reply With Quote
Old 01-09-2015, 11:36 AM   #135
LSJUNIPER
I have a question. If I use the original flywheel and mate up a T-5 trans will I need to use a ball bearing in the center bore like the one I removed?
Old 01-09-2015, 11:39 AM   #136
sidevalve8ba
Attachment 208681
Attachment 208682
I am using a pilot bushing in my T-5 installation but there are those who use a bearing like yours. I feel sure we will get comments either for or against.
Cars are like potato chips, its hard to have just one.
Old 01-10-2015, 05:38 AM   #137
LSJUNIPER
OK, Thanks sidevalve8ba...
Old 01-10-2015, 07:36 AM   #138
41LjH
41LjH's Avatar
In your first photo I noticed a chain hoist. I fabricated a couple of straps and bolted them to #1 and 5 exhaust ports and used a hoist to stabilize the front of my 8BA until I can make a side exhaust plate for my stand. Cheap peace of mind.
3 pedals, 3 gears, no valve-covers..
Now THAT is a hot rod !!
https://www.youtube.com/watch?v=ZmwwB34vxJE
41LjH is offline   Reply With Quote
Old 01-10-2015, 08:04 AM   #139
Walt Dupont--Me.
Attachment 208681
Attachment 208682
YES, Speedway has the right piolet bearing, fits the Ford flywheel and the T-5 shaft. Walt
Old 01-10-2015, 09:00 AM   #140
Bored&Stroked
Bored&Stroked's Avatar
Just saw this long thread - great project and congrats on building a flathead . . . love it! You sure have learned a lot along the way and I'm sure you'll be one happy camper when you get to start it and hear it run.
