Old 12-21-2014, 12:44 PM   #1
Fred A
Fred A's Avatar
Default '40 Dash Panel Brace?
Removing the dash in one of my '40, found a stamped brace with a rather factory appearance, about 9" long, running from the bottom, behind the battery gage up to the cowl. Of the relative many '40 Fords I've owned, this is a first for me. Could it be an original feature or just something someone added?
Fred A is offline   Reply With Quote
Old 12-21-2014, 01:06 PM   #2
Gumpy
Gumpy's Avatar
Default Re: '40 Dash Panel Brace?
Original piece ,,I do not re-use mainly for stability as I recall.....Merry Christmas my friend!
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford
Gumpy is offline   Reply With Quote
Old 12-21-2014, 02:36 PM   #3
deuce_roadster
deuce_roadster's Avatar
I put mine back in, I suspect it is to stiffen up the dash due to the steering column being bolted to it.
Old 12-21-2014, 03:10 PM   #4
okiedokie
okiedokie's Avatar
I had the same experience with the dash in my 40 sedan I have started on. I also had never seen one on the many 40's I have had. I was told they all had them when new.
okiedokie is offline   Reply With Quote
Old 12-21-2014, 03:24 PM   #5
Fred A
Fred A's Avatar
Thanks to all, No reason not to use it again. Must be like the engine pans that are usually tossed. Only lately has such disassembly been needed as the cars and I are about to get old. Good Luck: Fred A
Old 12-21-2014, 05:01 PM   #6
4dFord/SC
4dFord/SC's Avatar
I suspect most were removed at some point to facilitate working behind/under the dash (e.g., installing a radio).
4dFord/SC is offline   Reply With Quote
Old 12-21-2014, 05:47 PM   #7
Kube
Super Moderator
Kube's Avatar
They were in fact installed to each new 1940 Ford passenger car. I tend to agree with Deuce... strengthens the instrument panel near the steering column.
Old 12-21-2014, 06:11 PM   #8
19Fordy
19Fordy's Avatar
I hope someone would post a photo of that brace. I have never seen one.
Thanks, JIM
19Fordy is online now   Reply With Quote
Old 12-21-2014, 07:07 PM   #9
Kube
Super Moderator
Kube's Avatar
Thanks, JIM
Here ya go Jim...
Old 12-21-2014, 07:10 PM   #10
nospartsman
1940 Convertible and woody dash took a different length support brace.
nospartsman is offline   Reply With Quote
Old 12-21-2014, 07:49 PM   #11
Fred A
Fred A's Avatar
That is definitely the brace that I was surprised to find. From Kube's picture also sense the futility or inadequacy of my work on these cars comparing the level of restoration that I am likely to achieve gathering my best parts compared to the extreme, as new restoration that Kube achieves. Thanks again: Fred A
Old 12-22-2014, 09:29 AM   #12
Kube
Super Moderator
Kube's Avatar
Why would that be?
The dash panels at that point (closed vs. open car) are the same width.
Old 12-22-2014, 11:10 AM   #13
19Fordy
19Fordy's Avatar
Thank you Kube for posting that photo. Now, I very vaguely remember seeing that brace (or something like it) when i took my car apart many years ago.
Didn't remember to re - install it
Old 12-23-2014, 02:14 PM   #14
mike in las vegas
mike in las vegas's Avatar
I thought that bracket looked familiar. My 40 was disassembled when I got it. Just went digging through boxes and found the bracket with masking tape around it with a question mark on it. I will be installing it today. Thanks Ford Barn!!!!!!
mike in las vegas is offline   Reply With Quote
