Old 09-16-2014, 03:08 PM   #1
houseof34s
Default spark plugs for point judjing
what is the correct champion spark plug# for a 1940 ford flathead V-8 engine?
houseof34s is offline   Reply With Quote
Old 09-16-2014, 03:19 PM   #2
Tudor40
Tudor40's Avatar
Default Re: spark plugs for point judjing
H10, 5 rib with the black base.
Tudor40 is offline   Reply With Quote
Old 09-16-2014, 03:32 PM   #3
Kube
Super Moderator
Kube's Avatar
H10 with TWO rib. The so called "coke bottle" plug.
Five rib plugs did not come out until later and when installed in to a 1940 Ford should receive a point deduction of one point per incorrect plug.
Old 09-16-2014, 04:23 PM   #4
Don Rogers
Don Rogers's Avatar
From looking at Champion ads and Plug Charts, it appears that 2 rib H-10's were manufactured thru early World War II (1941-42). Some time during the war the design changed to 5 ribs and was used thereafter. See enclosed image.
Don Rogers is offline   Reply With Quote
Old 09-16-2014, 04:24 PM   #5
Terry,OH
Terry,OH's Avatar
The plugs do not have the Ford name on them.
Old 09-16-2014, 05:21 PM   #6
houseof34s
Where can Champion H10 two rib black bottom plugs be purchased?
Old 09-16-2014, 06:58 PM   #7
Kube
Super Moderator
Kube's Avatar
Just about no where. IF you find NOS, expect to pay $50 each. Good used? About $20+ each.
Old 09-16-2014, 08:30 PM   #8
rufus39
rufus39's Avatar
Kube is correct. These are very hard to find. I did manage to find a set at Hershey last year, but I had to look through several of the many vendors to come up with 8. Hershey would be my suggestion.
Good luck with your search..
rufus39 is offline   Reply With Quote
Old 09-16-2014, 08:36 PM   #9
ford38v8
ford38v8's Avatar
In reference to what Terry said, it is generally accepted that the two rib coke bottle with the Ford Script is a Service Replacement plug. The correct one is marked Champion H10.
Alan
Old 09-17-2014, 07:49 AM   #10
Kube
Super Moderator
Kube's Avatar
It is "generally accepted" yet NO ONE has proof one way or the other if the FORD plugs were installed upon the assembly line or were later, service parts.
Old 09-17-2014, 08:36 AM   #11
houseof34s
Smile Re: spark plugs for point judjing
Thanks for the all the great info V-8ers <> Much Appreciated For Sure.
Old 09-19-2014, 10:59 AM   #12
houseof34s
what is the correct spark plug gap for the modern version of the champion H10 plugs/
Old 09-19-2014, 11:15 AM   #13
Kube
Super Moderator
Kube's Avatar
Same as the authentic plugs
Old 09-19-2014, 11:26 AM   #14
houseof34s
would that be 0.025/
Old 09-20-2014, 10:16 AM   #15
DD931
DD931's Avatar
0.030", I think.
DD931 is offline   Reply With Quote
Old 09-20-2014, 11:21 AM   #16
Kube
Super Moderator
Kube's Avatar
Yes, .025".
